| Re: What poundage springs? Iain I have 450lbs on the front with a Chevy 350, I find it a little to stiff, If I every did it again I would possibly drop down to 400lbs.
| Re: What poundage springs? Iain - the spring rate is dictated not so much by the overall weight of the car etc., but more by the geometry of the suspension - distance from suspension pivot to wheel centre vs distance from pivot to damper mounting point etc. It is a leverage thing. Thus it is very difficult to check that what works for one kit would work for another. Maybe only another Viper owner could help. (unless there is a generic configuration to the suspension). Are yours too strong or too weak?
| Re: What poundage springs? Wilf, It's not exactly a matter of what's wrong with them... more like what's right with them. I didn't realise (many years ago when I got them) that since they were such a ba***rd to fit that they were actually far too long for the shock so even with the shock wound right down, they are still compressed. I am assuming that even if they were the correct length then they would be too strong as they were originally for the Jag V12 engine. To fill you in completely, all the shocks and springs were ordered with the kit from Ken "Knobhead" Cook. The front shocks look the right length but the springs are too long for them. The rear shocks themselves look too long as the car sits like a 4x4 even with the springs wound right down (but that's another problem to sort when I get the car back). I've e-mailed Bob Busbridge at Cobretti for his advice but I am still waiting a reply. Cheers... |
| Re: What poundage springs? Iain, In the early days of building my Viper (now owned by HowardB) I spoke with a guy by the name of Nigel at Avo (tel: 01604 708101). He advised 375Lb springs 83/4" long for the front to match the dampers supply by Cook. He was knowlegable and helpful.(No, not Cook!) As for the rear...I cut out the top mountings completely and moved them inboard to lower the back end by about 3". I would have done this anyway as the original build quality was garbage. As the rear geometry has now changed, the impression I had from "bouncing" the car (I know, not a proper engineering method), the spring rates as supplied looked ok as it seemed to have a reasonable adjustment range (soft to very hard). For more upright suspension mounting, the corresponding spring rate should be lower. Trial and error I'm afraid to get ride height/spring rate correct. Hope this helps....
__________________ Stan |
| Re: What poundage springs? Quote:
I measured what I considered to be an uncompressed length with the help of Martin (Tinka) and as I recall, I thought I needed 8 inch uncompressed and 5.5 inches maximum compression. Not exactly what you got advised... ![]() Now I'm really unsure... Cheers... |
| Re: What poundage springs? As Stan said, it is trial and error to get them right. At least your springs are too long so why dont you cut them down to whatever size you think best suits the car as far as ride height is concerned (bit by bit rather than reduce them too far) then once they are at the correct height if you think they should be softer or firmer you can use them as a pattern and have new ones made up to the correct length and poundage. Of course you might strike lucky and find that after chopping them down the firmness is ok although reducing the length does increase the poundage which from the sound of it is too high anyway. The important thing is to arrive at a starting point ie. the correct length. Tony |
| Re: What poundage springs? ' it is trial and error to get them right' No it's not, it's science. Given the factors that Wilf discusses in his answer and a few more, and knowing what bounce frequency you should be aiming at you can calculate everything you need to fully specify the spring you require. Then you 'tune' around a given starting point. 'reducing the length does increase the poundage' No it doesn't - a rate in Lbs per inch is a rate in Lbs per inch of compression of the spring. It is independant of the free length of the spring. We do not generally using rising or variable rate road springs or get anywhere near coil bound in our applications. The rate of a 'cut down' spring is EXACTLY the same as it was before you cut it. A goolgle on road spring design will turn you up a spread sheet that will design you springs for you - failing that a trip to the local library will get you the appropriate text book. Russ |
Am I glad you sorted the suspension out before I bought it from you. Cheers
__________________ Howard Viper under construction - full steam ahead and hopefully on the road this year. |
| Spring poundage? | kevchard | Viper Tech Forum | 33 | 04-10-06 09:43 AM |
| Jag Springs | LS430 | General Cobra Discussion | 0 | 01-10-06 06:51 PM |
| Springs: which way is up? | bc_suv | General Cobra Discussion | 4 | 18-06-06 04:10 PM |
| distributor springs | rover | General Tech Tips & Questions | 3 | 05-05-05 08:31 PM |
| What Springs | Karl | General Tech Tips & Questions | 1 | 18-12-03 09:59 PM |
