| Re: sumo front suspension Steve Not being funny but have you fitted them the correct way round. ![]()
__________________ AK 427 FOR SALE AK427 FOR SALE PistonHeads AK for sale Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
| Re: sumo front suspension Hello I can't help directly other than to say you are not alone. I too have the same problem and can probably find someone else too. To get a reasonable camber on the front wheels I too will need to wind the top joints so far out that they can't be safe. See: Crotch Rocket - another addition to my toy box (you can ignore my Eureka post at the end of this thread, putting it together this way was not safe) Originally I thought my uprights were wrong but not so. (confirmed by being sent some more by pilgrim that are identical to mine). So it looks to me that the parts don't fit right. When I had my body work delivered, the guy in the lorry was the chap from the Pilgrim workshop, he agreed it didn't look right at all but only suggested they send some replacement uprights. I've compared my car to a Granada based car, the difference was that the granada uprights are about 30mm taller which gets rid of the problem. So I expected that for a sierra or Granda bases car Pilgrim would supply different sized other parts to work together, not so, the only difference is that the mushrooms are fatter for the granda version. Currently I've got the top joints wound in so 2 threads are not engaged at the back of the wishbone, however, I have about 7 degrees camber so its definately not right. I wonder if the springs need compressing/loosening but doubt thats it? If you find any answer please let me know. The next thing I was going to try was get some longer thread drag links at stonleigh if I can. I did hear that Pilgrim had some with longer threads but I've not been offered any when I've discussed this problem with them. cheers Graham
__________________ Share your Cobra knowledge here on the Sumo Wiki ...and don't forget, building cars is meant to be fun!! |
| Re: sumo front suspension Miket, is that sierra based and if so, how many threads are you in at the back of the top wishbone?
| Re: sumo front suspension Quote:
| Re: sumo front suspension yes the top wishbone is fitted correctly, longer arm towards the front. I have tried bolting the bottom balljoint on top of the lower wishbone, this made it a bit better but not right. Pilgrim told me it should be bolted underneath, back to square one. I have stripped and rebuilt the front suspension at least ten times trying to find a better solution. I did hear that the early sierra upright is different to the later ones? ( mine are from a 92 ) does anybody know if this is correct? I have got to get it right eventualy because it is doing my head in |
| Re: sumo front suspension I thought the very last few sierras were different as mine was a 1993 model. the older parts Pilgrim supplied were the exact same so thats not it. Does anyone out there have a MkIII sierra based? If so could you please measure your uprights, perhaps from the contact point with the lower wishbone to the top of the mushroom for us to compare with please? Thanks.
ive just had another idea? any forseen problems in having the two arms on top wishbone extended by say 1 inch. by an engineering firm.... any thoughts? |
| Re: sumo front suspension Depends what is wrong. If it is the chassis that is wrong then get it put right if it is the Sierra stuff then again that needs to be corrected. If you just start lengthening parts as and if needed then it will through the geometry of the car out, then you will start getting things like bump steer etc etc. It might be a help if you could post some pictures on the site, also how far from Pilgrim do you live, if it is convenient it might be a good idea to pop it over to them to have a look at it. HTH In summary I think it would be a very bad idea to just extend the top wishbone.
| Re: sumo front suspension Right after reading this i checked the front on mine, especially as i have just acquired it an have not built one yet, anyway the top draglink is screwed completely into the top wishbone apart from 1 thread short of exposeing itself out the other end, this has given me about 2 degrees of neg camber, looking at it from and engineering point of view if this wishbone was made up to 40mm longer it would make the unit stronger by way of reduceing the length of screw exposed, hope this helps and lets know what the outcome is.
__________________ Ken has finally gone-he-he-he |
| Sumo front suspension arms | gareth08 | Pilgrim Sumo Technical Questions | 21 | 15-01-08 07:53 PM |
| Sumo Mk2 front steering/suspension | slider | Pilgrim Sumo Technical Questions | 4 | 04-12-06 01:29 PM |
| Sumo FRONT suspension set up | Kevin W | Pilgrim Sumo Technical Questions | 1 | 24-01-06 01:47 PM |
| SUMO FRONT SUSPENSION HAZARD !!!!! | dave | General Tech Tips & Questions | 27 | 31-08-05 07:13 AM |
| sumo 2 front suspension | mickcorn | Pilgrim Sumo Technical Questions | 1 | 01-06-04 11:59 AM |
