Old 23-04-06, 05:57 PM
Clarkson's Avatar
Speed junkie
rev counter
Hello all, can anyone tell me who makes this rev counter in the pic??
Does not work with msd box! Its ok till 3.500rpm and then bounces all over the place!
David
2nd baby due 23rd Jan.
Old 23-04-06, 06:08 PM
Re: rev counter
hi dave isn't this a smiths one?
usually a little label on the back....
neil
Old 23-04-06, 06:14 PM
Clarkson's Avatar
Speed junkie
Re: rev counter
That's what I think,but does not have a make on it.
David
Old 23-04-06, 06:20 PM
Re: rev counter
can't you tell by the wiring on the back as they have a common style of their own don't they...and perhaps why it won't work...is it a current type with an internal loop ,not the volt trigger type you perhaps need?
NEIL
Old 23-04-06, 06:32 PM
Clarkson's Avatar
Speed junkie
Re: rev counter
Well I was told I need a tacho adapter from msd,but need to know the make.
Worked fine with HEI dissy.
David
Old 23-04-06, 09:22 PM
andy l's Avatar
Re: rev counter
Hi Dave
Using MSD for Rev counter at 3500 revs needle dies but at idle is ok
MSD supply is 12 volt square wave which can cause dropout on various gauges.Reel Steel can supply conversion module, which when connected to rev counter feed wire, should stop problem. hope this helps Andy PS Reel Steel Tel 01895 440505
DAX TOJEIRO DE DION
CHEVY SB 383 STROKER 6.2Ltr 450 Hp
Tremec TKO 3550 3.54.1 Jag Diff
RCR Mk 1 GT 40 in build
Old 23-04-06, 11:11 PM
Clarkson's Avatar
Speed junkie
Re: rev counter
Originally Posted by andy l
Hi Dave
Thanks Andy.
David
Old 26-04-06, 03:55 AM
Re: rev counter
I had a simillar problem with a Crane electronic ignition unit. Turns out that the electronics changes the rate of the multi spark discharge above a certain revs, funnily enough it was also around 3500 rpm. Speedy cables sorted it for me with a new module inside the rev counter itself.
Not sure if this is relavant but it might help someone.
Colin
Rev Counter malbrook Pilgrim Sumo Technical Questions 3 25-04-05 12:39 PM
V12 Rev Counter Chris_Mann General Tech Tips & Questions 1 01-02-05 06:18 PM
Rev Counter r0lex General Tech Tips & Questions 4 20-04-04 09:54 PM
Rev counter Daz B General Tech Tips & Questions 4 07-10-03 04:47 PM
Hit Counter choogh The Cockpit 5 05-09-02 11:26 AM
