| Re: Could fueling problem be caused by elictrical fault ? Brian, The ignition warning light is in fact a charging light. Comes on with ignition to show that the alternator is not charging because the engine is not yet turning it. Start engine, put headlights and heater blower on, do the lights get brighter/blower run faster if you rev up. If not you need to chesk out the connections to the alternator/battery and in particular the earth straps from engine to chassis/ battery to chassis. If those are Ok get a decent auto electrician to check alternator output if you can't do it yourself, he will tell you if the alternator is duff. I had the same problem and the solution was a recon alternator. If the battery is not charged correctly this may upset the ECU assuming you have fuel injection and cause it to run in "limp home" mode, thus high fuel consumption. If you have a carb setup I can't see that the two problems are connected. Hope this is of use, Keith
__________________ Keith S Built a Sumo 3 RV8 Sold it to buy a 2000 Chimaera 4.5 |
| Re: Could fueling problem be caused by elictrical fault ? Perhaps your fuelling problem is caused by the fact that you have a BFO engine and drive it pedal to the, um, fibreglass...
| Re: Could fueling problem be caused by elictrical fault ? Quote:
__________________ Brian Dax-Built by DB Replicas-No 54 Various Upgrades & Modifications by Me 383ci Delivering Max Smiles Per Mile |
| Re: Could fueling problem be caused by elictrical fault ? Could it be that the alternator is taking more power to turn for some reason which is draining the power from the engine? Just throwing some ideas in the ring...
| Re: Could fueling problem be caused by elictrical fault ? Unless Brians supplying the power for half of Crawley, his alternator isn't big enough to make that much difference to his consumption
| Re: Could fueling problem be caused by elictrical fault ? They have electricity in Creepy Crawley? Amazing. I thought it was all gas.
They did think about running the town on petrol but they can't............ I am using it all
| Re: Could fueling problem be caused by elictrical fault ? Brian. Pull the wires off the alternator and give the contacts a clean and re try. If this does not improve the situation don't go to LeMans without a spare alternator!!!!
| ETB Speedo Fault | jonny m | Pilgrim Sumo Technical Questions | 6 | 14-01-08 03:54 PM |
| Rover V8 Fueling. | philip600 | Engine Tech Tips & Questions | 6 | 25-09-07 06:48 PM |
| What caused this ?? | Paul B | General Tech Tips & Questions | 12 | 20-03-07 05:53 PM |
| Fueling the Holley | cliffords | General Tech Tips & Questions | 23 | 13-11-06 11:46 AM |
| Wiring Fault | Phil McCann | Pilgrim Sumo Technical Questions | 3 | 04-07-05 11:27 PM |
