Old 23-08-06, 08:59 AM
tonym's Avatar
I drive, not polish
vehicle weights
At the weekend i checked the corner weights of several cobras and here are the total vehicle weights for each
AK Chevy383 1231kg 3/4 tank fuel
AK Ford 351 1259kg 3/4 tank
Pilgrim mk3 Chevy350 1064kg 3/4 tank
Pilgrim mk2 Ford V6 2.8 1034kg 1/4 tank
Pilgrim mk3 Rover 4.8 940kg 4/5 tank
Hope this proves useful to someone :thumb:
BIG TONE
Pilgrim for sale, dyno'd at over 300bhp PM me for details
My Gallery
Old 23-08-06, 11:27 AM
Ricky's Avatar
Re: vehicle weights
Why did you check corner weights? why not the whole car? only problem with just doing corners weights is that the anti roll bar needs to be dissconected before weighting, unless you have done somthing different :thumb:
Gardner Douglas
Old 23-08-06, 11:41 AM
maxGD059's Avatar
Re: vehicle weights
Tone -was that last Pilgrim yours then??
I thought your SVA weight was less than 800kg with your old 3.5 block, so what's happened here?
Ricky -I think you'll find few Pilgrims/AK's have anti-roll bars as standard
GD 302 RV8
Old 23-08-06, 11:46 AM
Dax SC's Avatar
Re: vehicle weights
Following SVA test:
Dax with big block Ford (ally heads) gross weight 1440kg with full fuel tank!
Mark Smith
Old 23-08-06, 12:01 PM
tonym's Avatar
I drive, not polish
Re: vehicle weights
Richard, Pilgrim state in the manual that the car weighs 850 kg when built with a RV8 so that was the figure i've been using. Interesting to note the difference though :thumb:
Ricky, checking the corner weights DOES weigh the whole car
BIG TONE
My Gallery
Old 23-08-06, 12:31 PM
lutman's Avatar
Re: vehicle weights
Measuring all four corners will give total weight. the anti roll bar only causes inaccuracy if trying to balance the weight on the front end - that is false readings if trying to equalise the front geometry.
Chris L
Chris Lutman - Daytona Coupe
Old 23-08-06, 12:59 PM
Irritant
Re: vehicle weights
I think I see where Rickys confusion might lie.
One can buy a corner weight checker for quick track use - it costs about £150, and simply lifts each wheel in turn a fraction and checks the effort to do it. Because of the way it works, simply adding the 4 results up may not give an accurate total vehicle weight. Just knowing the relative proportions between wheels can be enough sometimes for a quick check.
Using electronic 4 wheel scales though, (as they do at SVA, and as Tony did) does both at once, and accurately.
I would have thought that someone with as broad a reach of knowledge as Ricky usually claims might have known that, though.
Old 23-08-06, 01:09 PM
Clarkson's Avatar
Half arsed=half fast!
Re: vehicle weights
It can't be 940kg with you sitting in it??? :rotfl: :rotfl:
David
SRV8
New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign.
http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E
"Buy a Toyota, it drives itself"
Old 23-08-06, 01:50 PM
Ricky's Avatar
Re: vehicle weights
thanks Wilf, thats is what i didnt understand.:thumb:
Gardner Douglas
Old 23-08-06, 03:06 PM
dave's Avatar
The home of witty banter
Re: vehicle weights
Originally Posted by Dax SC
Following SVA test:
Hi Mark.
Isn't that the design weight (As completed on the SVA application form)?
The actual vehicle weight will be somewhat less if that is the case.
My builds are Gross at 1440 but actual weight is nearer 1130 on the scales for a SBC engine and stainless engine bay cladding.:thumb:
Pro Dax Builder
Current builds:-
Dax No.135---------Kirkham No. 2
DB REPLICAS
Low Volume manufacturer
LEMANS HARDTOPS FOR DAX AND PILGRIM
BB code is On
SVA weights? cobrascim General Cobra Discussion 7 19-06-07 05:30 PM
GD design weights phil General Tech Tips & Questions 2 22-09-06 07:33 AM
Corner weights chesterak General Tech Tips & Questions 6 24-07-05 07:51 PM
Corner weights Steve-J General Cobra Discussion 5 27-06-03 12:26 PM
corner weights steve_ram General Tech Tips & Questions 7 01-01-03 11:27 AM
