| Re: Spark Plugs Hi, What sort of mileage have you done? Spark plugs last for ages these days as long as you check the gap at each service. As for the leads these should last a good while too. I prefer NGK or Bosch spark plugs but it is a personal thing, as far as leads go I would suggest getting a kit (Morosso or similar) from somehere like Real Steel and make your own. (Easier than wiring a plug!) Cheers, Clive
| Re: Spark Plugs I have just bought a set of Platinium plugs from real steel and a spacer for the airfilter, blocked up the leaking spare advance pipe on the holley and richened the idle mixture , and she's running a treat again. was hunting at tick over and missing when very hot and bothered at Cadwell
__________________ On On |
| Re: Spark Plugs Now done about 8500 miles Its only me fettlin - Also want to neaten leads in a tray so longer ones are needed. Nothing wrong with the existing set up - it all works fine - Thanks for the suggestions. I have a Real Steel Brochure and will look at the Lead kit
__________________ CHRISC - SW REG REP - Cullompton DB No.46 If Ar*seholes could fly - this place would be an Airport !! |
| Re: Spark Plugs The best place to get the parts and have the work done is at a local cobra specialist about 15 minutes from you. I hear they are very competitive and do a great job.
__________________ ANTHONY Pro cobra builder Current build No. 16 |
| Re: Spark Plugs Hi Chris Try Brain at Repower for your bits Tel 01903 522900 hope this helps PS. may see you sunday Andy.:thumb:
__________________ DAX TOJEIRO DE DION CHEVY SB 383 STROKER 6.2Ltr 450 Hp Tremec TKO 3550 3.54.1 Jag Diff RCR Mk 1 GT 40 in build |
| what spark plugs? | jamesandlouisa | Engine Tech Tips & Questions | 5 | 04-10-05 02:21 PM |
| Spark plugs for SBC | kurrmet | General Cobra Discussion | 8 | 14-08-05 06:10 PM |
| Spark Plugs | tonyevans | General Tech Tips & Questions | 3 | 20-03-04 06:48 PM |
| the best spark plugs?? | MARTIN123 | General Tech Tips & Questions | 9 | 26-11-03 07:48 PM |
| Spark Plugs | Miket | General Tech Tips & Questions | 10 | 04-07-02 12:51 AM |
