| Ram header/expansion tank quicky I have recently ordered a Ram spec header/expansion tank with filler cap There are two outlets (excluding the cap neck overflow), one is a bleed connection to top of radiator RHS, the other is to be tapped into the main tube from thermostat to top LHS of rad and is for filling. Thing is they are just 3/8 which is fine for the bleed connection but seems seriously slow for filling. I would expect to disconnect hose from stat and fill there. Also, it is a pain to route and plumb the filling 3/8 hose so I want to leave it out. So question is: is there any disadvantage to speccing the tank with just a bleed connection to rad? I hope this would handle any expansion and contraction of coolant and would probably be OK to occasionally top up coolant. It would also provide the path into the pressure of the system to allow the cap to function. So is there any advantage with 2 outlets? Sorry if this is a stupid question!
__________________ AKA Ed and not computer literate enough to change \'bitsilly\'. People say to me \'hey you, get out of my garden\'. |
| Re: Ram header/expansion tank quicky Cheers Steve some fair points. What I'm planning is the same but initially blanking off the second bleed pipe to the top, only because of cost, that said I now have a bit of -10 braided left over so if I can get Roger in time and increase the size of the outlet I'll use it (onto a spur welded into the very nice chromed toilet down pipe I have which fits perfectly! Just keep that to yourself or I'll never live it down)! It will be the same as your photo bar the plain cap, I'll undo the jubilee clip initially.:boohoo: Could all members please stop selling perfect cars for less than mine is costing to build with bits of toilet!!.
| Re: Ram header/expansion tank quicky OK, I still dont understand why you feel you need to increase the header tank outlet pipe size though; flow is totally ireelevant, and the standard size is perfect. Oh, I think its a given that these cars cost more to build than theyre worth
__________________ Regards Steve We're not here for a long time, We're here for a good time... Enjoy it while you still can.... |
| Re: Ram header/expansion tank quicky Quote:
| Re: Ram header/expansion tank quicky The one and only reason is I have 15 ft of aeroquip -10 braided hose! A larger spur costs the same as a 3/8 one! Result: free pretty hose which does the same job.:drive:
| Re: Ram header/expansion tank quicky Now I understand!!!
| Sumo fuel tank and expansion tank, chevy pump | laosui | Parts for sale | 0 | 10-08-07 08:51 PM |
| Stainless/Chromed Expansion tank and Washer tank? | cobrasrgrate | Pilgrim Sumo Technical Questions | 1 | 18-03-07 09:40 PM |
| expansion/header tank query | Speedy Gonzales | General Tech Tips & Questions | 0 | 01-08-06 04:55 PM |
| header/expansion tank position for LS engines | chris m | General Tech Tips & Questions | 6 | 18-11-04 09:30 AM |
| GD Header/Expansion Tank | JP | General Cobra Discussion | 2 | 10-03-02 07:35 AM |
