| Bending stainless Hi guys, I have a project that is to be revealed when the car is launched but must currently be kept under wraps! However, can I use oxy to bend stainless - i need to bend 8mm tube with a 3.5mm internal diameter in a fairly short radius but only to about 10 degs. I don't think that normal bending techniques will work to create the smooth radius that I need. Would using oxy degrade the stainless or will it assist if I am careful? Cheers, Jon
| Re: Bending stainless Jon, you can bend as you suggest without compromising the steel, the heat will keep the radius contained, so you don't end up with a sweep instead of a bend. Always overbend a few degrees and then pull back to req. angle. This will minimise tbe tube going oval in the bend although with that kind of guage its very doubtful . Pete (Ex RR coppersmith) |
| Polished stainless | Harry-G | General Cobra Discussion | 1 | 18-09-05 01:24 PM |
| bending on the drag link | Per_Inge | Pilgrim Sumo Technical Questions | 0 | 30-08-05 06:16 PM |
| Stainless Sheet | gwak76 | General Cobra Discussion | 1 | 20-07-04 10:21 AM |
| Brake pipe flare & bending tools | Martin427 | The Loan Forum | 2 | 02-05-02 07:40 PM |
| Flaring & Bending Tool | JP | General Tech Tips & Questions | 0 | 04-09-01 11:07 PM |
