| Re: Twin turbo rover v8 Come one then,what have you bought?? The other day you wanted a trailer! I have seen that setup once in a rangeover think it was done by Janspeed.
__________________ David SRV8 New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign. http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E "Buy a Toyota, it drives itself" |
| Re: Twin turbo rover v8 I have a feeling Eric may have in his younger years, may be wrong though (PM Osgood). Jim |
| Re: Twin turbo rover v8 Can't say I have experience with them having never seen one before but I am guessing it may be fairly simple. It looks like there are two tubes missing from your photos, that link the two intercoolers to the carburettors. There is a bit of history about the Janspeed setup on this page. http://www.roversd1.nl/sd1web/jspeed.html It looks like Janspeed attached the SU carb to the end of the turbo, where as your one seems to have the carbs in the standard place on top of the engine. I didn't think you could use the SU carbs under pressure as they rely on vacuum to lift the dampers in the dashpots. Maybe these carbs are modified to cope with forced induction. Looks good, although it May need a bit of a clean Any idea what size the engine is? Craig
__________________ Dax Tojeiro, + 355 Chevy + Tremec box = no more money! TWM Fuel injection now up and running! Sounds and runs superb. Polishes to date = 27 |
| Re: Twin turbo rover v8 Personly I would go with the small block Ford option. The turbo kit would sell well on E-bay. It would give you the chance then to add the lovely 180 degree exhaust system that gives the GT40 such a lovely sound. Craig.
| Re: Twin turbo rover V8 From what Rob used to say about his supercharged Chevy, it was mind blowingly fast when needed ( most of the time in Rob's case ) but very drivable and economical ( Ha Ha ) when driven steadily.
__________________ East Midlands Area Rep Martin Mega Squirt in and running ! Car Sprayed and looking Fab |
| Re: Twin turbo rover V8 Quote:
I agree with Tinka here. Superchargers/turbochargers are great fun with tons of go BUT bloody expensive to put right when they go wrong.(4 engines this year so far Not sure about the economical bit as I tend to use 10 times the amount of NoS than I probably did fuel with the blower.
__________________ Gareth 347 Ford T5/wc |
| any one need a 4l twin turbo | leestewart | General Tech Tips & Questions | 0 | 15-05-07 04:16 PM |
| Twin turbo Ford GT | simon | General Cobra Discussion | 2 | 30-08-06 01:19 AM |
| Twin turbo chevy 350 | Daxman | General Cobra Discussion | 4 | 10-09-05 07:43 PM |
| Janspeed Twin Turbo conversion | DrFelch | Engine Tech Tips & Questions | 12 | 07-05-04 01:23 PM |
| twin turbo | COBRA KEV01 | General Cobra Discussion | 3 | 24-11-02 11:12 AM |
