Old 16-04-07, 08:01 AM
Gear Lever
Can any help here?
Being fiscally challenged, (tight) can anyone pass on the dimensions of the cranked 427 gear lever? As I have made most items for the Cob I want to have ago at this.
Overall height and angle of the set in the lever would be useful, and any other dimension you can take off it would be a great help.
Don’t worry about the reverse lock out lever dims. The lever will fit a Tremec TKKO.
Thanks again.
Old 16-04-07, 03:32 PM
ldtopham's Avatar
Re: Gear Lever
Originally Posted by Bigblock
Can any help here?
Thanks again.
Funny that, I was just going to post the same question today!
Watching with interest,
Lee
My car pics
Old 16-04-07, 11:27 PM
Gear Lever
Come on you lot, someone must know the dimensions, I have seen pics on the site with some of you with this gear lever.
I will swap these details with the details of how I managed to get a set of the Lucas L542 square rear lights with amber top indicator lens.
Old 16-04-07, 11:49 PM
kayjayd's Avatar
I've got one sitting on my bench in the garage which I'll measure up for you in the morning and post the results.
Kev
AK - 383 chevy
Old 16-04-07, 11:55 PM
Thanks,
May the ladies of a 1000 brothels make your every wish come true
Old 17-04-07, 09:37 AM
ldtopham's Avatar
Re: Gear Lever
Are we building the same car I went to the scrappers last week to find a suitable donor for flat amber lenses to do just the same!
I can't help with the gear lever dimensions but am interested in your light mods, could you pm me with how you've done it?
Lee
My car pics
Old 17-04-07, 11:07 PM
dingocooke's Avatar
Or you could do it like this? (indicators mounted on stailess plates bolted to rear of nudge bars using nudge bar studs) looks kind of a period 'Ive added indicators' mod to me (OK Im sad)..
Steve
We're here for a good time...
Old 17-04-07, 11:41 PM
Don’t do this unless you are confident and have a steady hand.
Strip down the light and grind out with a drebble or whatever you have the centre of the top half of the lens. Take it very slowly and a bit at a time leaving just the sides.
If the wife/girlfriend ask “what are you doing” for gods sake don’t say “cutting up a pair of £95 brand new rear lights if you want to retain any balance left on you credit card, because if you can cut up new rear lights she can also spend an unnecessary amount on unnecessary items in the shops.
You should be left with a red lower section and just the sides of the top half.
Then measure the thickness of the amber lens you are going to use, I found Lucas L694 worked out perfect. File carefully of the remaining sides this amount so when the new amber bit is grafted on the faces are level.
Make a card template of the shape of the lens you need from the modded one and transfer this to the amber one. If you are careful you will see from mine that you can even get the Lucas marking to show. Cut out the amber lens and leave at least 3-5mm over.
Tape the new amber lens in position on the cut up one and fettle the sides till the lens fits flush without any gaps.
Tape this in place and then use caulking or similar to seal any gaps on the out side of the fitting.
Turn the lot over and get it level.
Mix up a clear or slightly tinted amount of GRP resin; mix in the hardener very carefully not to make any bubbles. Fill the new lens so it covers the joint between the grafted amber lens and old fitting.
When dry carefully shape the new amber lens to match the existing shape. Rub down with 1500 w&d and then with a spot polisher polish the lens back up to a shiny finish.
All that is left to do is to make a lamp holder for the rear and ensure the light doesn’t bleed into each other.
Sorry it’s short but it’s difficult to explain. The car will be on the road soon hopefully so you could have a look then.
Old 17-04-07, 11:43 PM
Now where's that gear lever dimensions!!!!!!!!!!
Old 17-04-07, 11:49 PM
Miket's Avatar
Fully Paid Up Grandad
Bigblock
I admire guys with ingenuity, especially building a car to that quality in a garage of that size, well done
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Hole for Gear lever cliffords AK Technical Questions 2 23-04-06 06:26 PM
Gear Lever Phil McCann Pilgrim Sumo Technical Questions 3 25-03-05 10:47 AM
TKO gear Lever salmon General Tech Tips & Questions 1 01-10-04 12:51 PM
BW T5 gear lever macca General Tech Tips & Questions 1 26-07-03 01:23 PM
Rover V8 gear lever mod Jake Pilgrim Sumo Technical Questions 2 20-05-03 11:04 AM
