| Satisfying day in the garage today. Whilst I'm waiting for some steel plate to turn up to finish my harness brackets I thought I would spend a bit of time tuning the engine. Ford 351C Holley 750V/S, MSD ignition. I originally had a double pumper on top but hopefully made the correct decision to swap it for a vac secondary with Ken from EDA. He said it had only seen dyno time but was unsure as to why it never left the shop? This in no way is a slur as Ken did promise to swap it for another unit should it prove faulty. I basically had it running with base carb and timing settings but driving on private road I increased the timing to 16 BTDC from 12, limiting total to 34 at 2950RPM. Idle is now 850 and it starts to advance at 1100rpm. Starts real smooth with no excessive compression nor any run on after turning it off. I used the black MSD bush (+18 mech) and 1 silver light and 1 silver heavy adv spring. The Vac is connected to timed port. I then checked the idle bleed screw settings and found that I could screw them all the way in (lean) and the engine would continue to run. It actually idled real smooth at this setting but something was wrong as it should have cut out. I wondered if I had a reverse idle Holley but there isn't a 750cfm version listed so needed to investigate further. I use an Innovate wideband sensor to check A/F ratio but it wasn't playing ball. It works for about 10 seconds after starting up before reading above max readable lean (6 lambda!) and was oscillating all over the place. I checked for vacuum/ intake/ exhaust leaks but all seemed ok. I may have the sensor bung in too hot a location this I need to check out. I decided to tune using the vacuum gauge method on full manifold vacuum and manged to get 13" of vac. It would still run with the bleed leaned right out so I wasn't happy. I pulled the carb and got to stripping it down. With the backfiring I also wondered if I had blown the power valve as I didn't know at this stage whether it had blow out protection. Even though it had stood for 2 years there were no signs of gummy petrol inside. More worrying was the small amounts of swarf still attatched to the tiny drillings in various places of the metering block and plate from manufacture I removed all these, took note of jet/ power valve and metering plate sizes and generally gave it a clean up/ inspection. The primary idle transfer slots were showing 60 thou below the primary butterflies and holley reccomends a max of 40. This would be the reason for idle being too rich as the idle transfer was feeding the idle A/F instead of the curb idle. A quick tweak of the secondary idle transfer slots to allow the primary to be adjusted by means of the idle speed screw and fingers crossed. I also noticed that the gasket between the venturis and base plates was slightly in the airflow down the venturis so trimmed it back with a scalpel. All back together, a quick tap of the accelerator pump showed too much clearance. Adjusted so that as soon as the throttle moves it tips in (even got the lingo down now!) and idle screws set 2 turns out, it fired up fine. I checked the float levels, both levels at the base of the sight hole, tweaked the idle bleed screws both the same amount and got 15" of vac. It does now stall if I lightly seat the screws Bonnet down into 1st and whoa what a difference. Very responsive and very smooth with no puff of smoke on initial acceleration, happy as a pig in muck. I can now shift into second without it wanting to die. Having never driven a big V8 before I initialy thought I might have gone daft with the cam choice or something. It was the first time I have dabbled with a holley and found the whole day very satifying. I can thoroughly recommend ISBN10:1845840062 'How to Build & Power Tune Holley Carburetors' by Des Hamill. Now need to suss out why my o2 meter isn't working as it should so I can data log fueling through all rpms Must sort small leak from sump pan gasket too as I am leaving trails on my test ground! SVA might be an idea too. For anyone who has a holley and it needs tweaking I would buy the book and have a go, 1/2 a days work has made such a difference! Cheers.
__________________ Lee Gardner Douglas Mk4, Ford 351C, TKO600, 3.31 LSD, Sidepipes, 15" wheels. Black, basic and buisness like. My car pics |
| Well done mate good write up, I have spent all week finally tweeking my double pumper with squirter jets and pump cams,that it runs so well I am now getting very high teens in MPG!!
| Quote:
Do you have to adjust on them a regular basis or they pretty much stable once set?
| Quote:
There is much more you can do,but sounds like your learning fast. I got lots of help and support from Tim Adams with lots of late night phone calls. What jets and P/V have you got fitted??
| Oh re your lambda probe,where have you fitted it??sounds like the locition is not hot enough or a exh leak!!
| Quote:
The power valve I think is a 6.5. Nothing stamped on the flats but on the body. clockwise from top 6 then 5 at 3 o'clock, 2 at 6 o'clock and 0 at 9 o'clock???? I will go with 6.5 for now. I'll run my vac gauge inside the car when I'm tuning the p/v and that should be a good pointer. I wondered if it was a 2 stage type but it isn't. It a high flow type with the 2 cut outs and correct gasket. I did notice 2 gaskets fitted. With one the p/v doesn't seal, I could see no problem with with running 2. The book mentions leaning out 2 jet sizes for evry 2000ft of alt above sea level, I'll go with what I have for now and see how the data logs come when I have the chance to get it on the road proper. Bumping the timing up and sorting the fuel has lowere the exhaust noise considerably too
| Quote:
Your going the right way about it.
| Quote:
| Quote:
| Garage | robert | General Cobra Discussion | 0 | 07-02-07 01:20 PM |
| CRC Garage | martin_t | Feedback, Membership and Help | 1 | 30-04-06 11:35 PM |
| How to get into my Garage | Alaska Gray | General Cobra Discussion | 8 | 29-06-05 09:50 AM |
| CRC Garage | robert | General Cobra Discussion | 12 | 06-03-05 11:35 PM |
| what a garage | chiffer | General Cobra Discussion | 12 | 25-02-04 09:31 PM |
