| Tacho Drops To Zero Hi Everyone I have got a 'new' problem, after fitting a msd 6 series ignition unit about 6 months ago i have now got a tacho that drops to zero when i acclerate this has only just started to do this - any ideas ???????????
__________________ Cheers !! Terry If It Ain't Broke Don't Fix It !! www.topclassphotographics.co.uk |
| Thanks for your reply Wilf I dont know if this applies as i have not used the tachometer output terminal on the side of the msd ?!?
| I think you can get a simple adaptor from MSD that will sort out the signal for your tacho. |
| Terry - I think you should use teh MSD tacho output - the main output to the coil might be a bit fierce for your tacho, plus of course an MSD sparks 3 times per "go" below 3000 rpm, that is why the tacho output is there. Iain - I had forgotten about the diodes! Anyone care to advance a theory as to how/why they work? (not the diode, but the practice of putting one into the line to the tacho).
| I had this problem not that long ago with my MSD unit,the tach adaptor did not work for me! I spoke to speedy cables and there is a mod,but you have to send in your tacho and pay £50+ vat! I was better of buying a new smiths tacho. You must use the tacho output on the MSD box and NEVER add any extra wires to the coil +or- as it runs at 500volts!
| Thanks Guys I will look into your suggestions
| Connected my tacho to the tacho terminal on the msd unit and worked fine?
__________________ Steve Richards LS1..........so smooth.........so economical! Growing old is inevitable - Growing up is an option |
| Help with tacho connections | jools | General Cobra Discussion | 3 | 12-05-07 03:53 PM |
| ETB Tacho / Msd 6AL Ignition | rudy | General Tech Tips & Questions | 11 | 15-02-06 06:47 PM |
| VDO Tacho problem. | kurrmet | General Cobra Discussion | 3 | 18-12-05 06:55 PM |
| Tacho Blues!! | big_guy_unlimited | Engine Tech Tips & Questions | 1 | 12-06-05 10:41 PM |
| ETB Tacho problems | David Horsnell | General Tech Tips & Questions | 4 | 17-05-05 01:52 PM |
