| Squeaking rear brakes Got a Jag rear end with inboard discs and suffering from a loud high pitch squeal when braking at low speed. Tried EBC Green pads and that didn't cure it so now have Ferodo DS2500 pads fitted and it still makes a racket !!! Thus, l figure it isn't the pads and need an "anti squeal shim kit" or something similar. Any ideas/cures gratefully received..... |
| Hi Beeb, Have you tried coating the back of the pads with Coppaslip? Usualyy cures the problem. If not Hermetite do an aerosol spray called Anti brake squeal (Or similar)
| as Dave says, try pulling on the handbrake, with jag IRS the little (crap) handbrake calipers are often the culprit; if so undo th emounting bolts for the handbrake calipers, clean, copper grease and re assemble; had same problem on my old RAM a few years back.
| Driven the Cob to work today and did as suggested - used the handbrake gently at low speed and the squeaking stopped. This tells me it ISN'T the handbrake and definitely the actual pads. Where can l buy this "anti squeal material to stick on the back" and what is the product/brand called? |
| That test tells you it is the handbrake calipers if the squeaking stopped on handbrake application; in other words there is nothing wrong with your main brake calipers at the rear. So now you need to buy some copper grease (coppaslip is a common tradename) and put some on the back of the handbrake pads and some on the bolts that the handbrake calipers are mounted to the main calipers with. Job done.
| What they all said - it's the handbrake. Try just prising the copper pull-off "legs" apart a touch, to lift the pads off the discs just a fraction (maybe 0.5mm more is all). Also, if you don't have then fitted, fit some pull off springs to both actuating arms.
| Jag XJ6 axle - Outboard rear brakes | GDmerlin | Feedback, Membership and Help | 15 | 20-01-07 08:14 PM |
| Binding brakes (Jag rear) | Dave Williams | General Tech Tips & Questions | 8 | 28-11-06 08:42 AM |
| Squeaking rear brakes | Glyn_Turner | General Tech Tips & Questions | 5 | 01-06-06 06:39 PM |
| Rear brakes | darren | Pilgrim Sumo Technical Questions | 4 | 21-03-06 05:28 PM |
| Rear Diff and front brakes........Ford styleeeeee | fakesnake | General Tech Tips & Questions | 1 | 22-11-01 05:41 PM |
