Old 11-10-07, 09:02 PM
Nick S's Avatar
Question Does BZP mild steel react with petrol
My latest attempt to retain the moving foam / plastic gauze in my fuel tank has failed. I have inserted a 150mm length of BZP mild steel threaded rod through one of the sender unit fixing holes to keep the foam away from the sender float. This has almost worked, however I will have to modify this to work correctly. My question is this;
The fuel tank is aluminium and the threaded rod is BZP mild steel, will any type of reaction occur or is it bad practice to have this type of threaded rod near petrol?
Cheers Chaps
Nick
Magnum Cobra & 350 Chevy
We don't stop playing because we grow old; we grow old because we stop playing
Old 11-10-07, 09:08 PM
Club Sec/Rep Liason
Most fuel sender bases as well as most carb bolts, And most tin top fuel lines are BZP steel. So I can't see a problem
AK 427 351C T5wc
Old 11-10-07, 09:09 PM
Veteran polisher.
No reaction will occur between zinc plate steel and fuel but steel touching aluminum does corrode.
I would try to re-make the bar in aluminium for a long term solution or prevent the steel directly touching the tank.
Polishes to date = 17
Old 11-10-07, 09:15 PM
Nick S's Avatar
Could I get M6 aluminium threaded rod of the shelf?
Old 11-10-07, 09:19 PM
Veteran polisher.
No
Threaded aluminium rod would be no good to anyone as it is too soft to hold a decent thread. You would have to make your own from a piece of 6mm diameter or 1/4" diameter rod.
My main concern was if this rod is going to tough the sides or bottom of the tank. If you can keep it short or place a rubber or plastic cap on the end to prevent contact you will be fine using steel.
You can use a copper grease type substance at the sender end to prevent corrosion.
Old 11-10-07, 09:23 PM
Why don't you just fit a tube sender
Old 11-10-07, 09:24 PM
Veteran polisher.
This makes interesting reading.
http://en.wikipedia.org/wiki/Galvanic_corrosion
Land Rovers suffer badly from this as the chassis frame is steel and the body parts are aluminium. Add a bit of salt water from a winters road and the body fixing points can completely dissolve within a few years. All they needed to use was a thin rubber gasket in between the two and there wouldn't be an issue. I guess that would cost too much though?
Old 11-10-07, 09:28 PM
Nick S's Avatar
Hi Martin,
My hole for the sender unit is in the side, not the top. I have tried to get a cranked one without success.
On another point, can I nip over at some time to have a look at your side screens?
Nick
Old 11-10-07, 09:31 PM
Nick S's Avatar
No
Sorry Craig,
That goes straight over my head, can you expand a little?
Nick
Old 11-10-07, 09:36 PM
Nick S's Avatar
Chris,
If I don't fix it soon, it will be mounted in the skip.............
AAAAAARRRRRGGGGGHHHHH.
Nick
What plugs for mild 351W? dingocooke General Cobra Discussion 14 16-04-07 08:42 PM
Beg, Borrow, Buy, Steel..... BenBaron General Cobra Discussion 4 07-11-06 12:44 PM
Real Steel cliffords General Tech Tips & Questions 16 24-07-06 10:51 PM
Carbs: 350ci Chevy mild tune Abyss General Tech Tips & Questions 31 14-03-05 03:42 PM
Mild back fire Ian D c General Cobra Discussion 1 06-01-03 08:04 AM
