Old 07-07-03, 09:50 PM
at last,a rolling chassis
be sliceing and spliceing this chassis for two months now, at last fabricating engine mounts etc, getting somwhere now at last?
Old 09-07-03, 12:42 AM
RE: at last,a rolling chassis
any advice before i go any further is appreciated, thanks
Old 09-07-03, 12:56 AM
Miket's Avatar
Fully Paid Up Grandad
Martin
I don't think a spirit level will work as a rear gearbox mounting.
:tu :tu :tu :tu :tu :tu :tu :tu :tu :tu :tu :tu :tu :tu :tu :tu
Sorry couldn't resist.
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 09-07-03, 10:34 PM
When you put your foot down from a standing start there is going to be a hell off a lot of force on the top rear shock mounts. I don’t know, but do you think they’ll hold? Especially with the leverage they have sticking out from the chassis like that.
Just trying to help,
Andy
http://www.corporanda.com/cos-race.gif
Old 09-07-03, 10:43 PM
Also, I think you might find the rear chassis twisting when cornering unless you add some form of triangular structure at the back. But then again I might be wrong. Can’t see the front clearly to comment.
I don’t know if you have been, but you shouldn’t leave your rocker covers off when working as you could get little bits of grit/dust in around the valves, which will create problems later on.
Andy
Old 10-07-03, 12:22 AM
thanks chaps(spirit level )nice,right the engine was put in at the end of the day to ,start making the engine mounts, and the heads are faced,with masking tape,only sat on the block which also has masking tape over faced block,behind the flitch plates are some triangle stainless steel cross bracing,also the shocks have only been positioned for ride height and travel ,have now made and folded 4 mm plate top mountings, with 45 braces on, engine and box out tonight for painting , engine mounts done now ,(folded) will weld on tonight, the main reason for fitting the engine was to check the prop length, found the front prop off a range rover is ideal fit, just modified the diff flange(granada lsd 3.32)to take the bl flange, thanks for your time and comments
rolling chassis tooliesjock Newbies 2 03-09-06 10:48 PM
Dax Rolling Chassis Builders madjohnny DAX Technical Questions 20 18-05-06 06:28 PM
Rolling Chassis mclark DAX Technical Questions 4 03-11-03 10:30 AM
DAX Build - How to get a rolling chassis mclark General Cobra Discussion 4 11-08-03 04:06 PM
Rolling Chassis Arrives! SimonP General Cobra Discussion 13 14-06-03 12:21 AM
