  #11 (permalink)
Old 10-01-08, 01:44 PM
Clarkson's Avatar
Speed junkie
I might even be full of water,or corrioded electrical termanls.
David
SR Cobra, 350CI Powered by Clarkson's engines.
2nd baby due 23rd Jan.
  #12 (permalink)
Old 10-01-08, 01:51 PM
Clarkson's Avatar
Speed junkie
Also make sure the ign key returns in the outer door handle barrel.
David
  #13 (permalink)
Old 10-01-08, 01:52 PM
Miket's Avatar
Fully Paid Up Grandad
Yes it does.
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
All I ask is a Chance to prove that money can't make me happy.
  #14 (permalink)
Old 10-01-08, 01:56 PM
Clarkson's Avatar
Speed junkie
Originally Posted by Miket View Post
Yes it does.
Sounds like the pump. See if you can Rob one from the local scrapy. They cost a few hundred pounds.
David
  #15 (permalink)
Old 10-01-08, 06:54 PM
Hi Dave,
Thanks for the response. Symptoms are this:
Leave car running varying revs & the needle rises gradually upto 130°C.
Turn heater upto full & the temperature is intermittment but genrally blows cool.
Gradual water loss.
No obvious signs of water leaks.
I have checked the oil on the tip of the dipstick & it is not emuslified. I have also changed the stat, (that was a b*stard of a job!) but problem persists.
My missus is a very steady driver so it does seem odd the head gasket has gone - would a compression test help to prove / disprove a blown head gasket?
Regards,
Martyn
  #16 (permalink)
Old 10-01-08, 07:01 PM
Clarkson's Avatar
Speed junkie
Originally Posted by Martyn-ak427 View Post
Hi Dave,
Gradual water loss.
Regards,
Martyn
Needs a water pump,the plastic impeller has fallen of the back of the pump. I have never seen a blown head gasket on any of those engines in 14 years! If there is no water returning to the top of the header tank, then the water is not circulating. It's a crap job and will take you 4hrs. While your at it, you might as well replace the cambelt.
David
  #17 (permalink)
Old 10-01-08, 07:47 PM
Veteran polisher.
What a bad idea, Using the cam belt to drive the water pump.
We had a contractor in at work for a few months recently and he had an Audi A4 diesel. One morning he phoned up to say the car had stopped and was being recovered to a garage. It turned out to be a seized water pump had stripped the teeth off the cam belt and knocked out the timing.
New water pump, belt, cylinder head with all valvetrain components and labour cost him about £1600.
TWM Fuel injection to fit.
Polishes to date = 17
  #18 (permalink)
Old 10-01-08, 07:55 PM
dingocooke's Avatar
The old front wheel drive escorts did the same thing, water pump would sieze strip the cam belt of a few teeth and then you waved goodbye to 8 valves and sometimes the whole engine (if it clocked off at speed LOL); could be worse; my ducati 916 needs a pair of timing belts every two years religious as ducati wisely designed the cam belt wheels such a small dia it knackers the belts quickly...doh Oh and you have to take half the bike to bits to do the job!!
Steve
We're here for a good time...
Crendon CR427 Chassis no 0029
  #19 (permalink)
Old 10-01-08, 08:59 PM
Clarkson's Avatar
Speed junkie
Yes all very common, the water pumps and cambelt tensioners/rollers tend to brake before the belt does!! Thats why dealers always fit/replace eveything to cover themselves,that's why it ain't cheap.
David
  #20 (permalink)
Old 10-01-08, 09:50 PM
Cam belts suck!
Timing chains rule!
Suspected blown head gasket Nick S General Cobra Discussion 51 11-05-08 11:22 PM
Head gasket sealant Sidecarbod General Tech Tips & Questions 2 09-05-06 01:56 PM
Composite head gasket RV8 3.5 martin_t Engine Tech Tips & Questions 8 23-04-06 06:15 PM
Head Gasket set for 302 Jason Engine Tech Tips & Questions 4 20-12-05 08:58 PM
Head gasket advice hfbradley01 Engine Tech Tips & Questions 14 10-02-05 07:12 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 Ramblings
