Old 10-01-08, 11:42 AM
Martyn-ak427's Avatar
Head Gasket - Not Cob Related
Guys,
I appreciate this isnt Cobra related but does anyone know how easy it is to change a head gasket on a modern engine such as a Golf 1.8 GTI Turbo? Reason I ask is the missus's has just gone & the garage are quoting £600 to renew it! The car itself is only worth approx £2.5k so am reluctant to spend that sort of money if I can do it myself over a weekend?
Any help / advice appreciated.
Martyn
AK with tyre-lighting 393ci Ford Stroker - 480hp & 475ft/lbs! - (build about 75% complete..)
Old 10-01-08, 11:54 AM
Veteran polisher.
Can't see a reason why you couldn't do it yourself.
I did one a Peugeot a few years back and that was easy enough. Do they make a Haynes manual for it?
You will need the new head gasket and any other gaskets you may remove to get to the head, New timing belt and possibly new head bolts.
You will also need to know the torque or angle required when doing up the bolts.
Some engines have very long bolts that go right through the head and block and hold the main bearing caps on. If it's one of these you will also need to remove the sump and secure the caps in place before removing the bolts.
Good luck
Polishes to date = 16
Old 10-01-08, 12:11 PM
Clarkson's Avatar
Speed junkie
Originally Posted by Martyn-ak427 View Post
Guys,
Martyn
Too expensive!
I would do it for £250 +parts.
Never heard of a head gasket failure on those engines. Sounds like the water pump has failed! (Plastic impeller broken) Is there water/oil mix?? Or just overheating?? I work for VW/Audi.
David
2nd baby due 23rd Jan.
Old 10-01-08, 12:15 PM
Miket's Avatar
Fully Paid Up Grandad
Dave, while we are talking VW, any idea why the central locking on a 1999 Polo should stop working, it was intermittent at first, now it has packed up completely.
AK 427 FOR SALE
AK427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 10-01-08, 12:29 PM
Clarkson's Avatar
Speed junkie
CDL in polo's are vacuum operated, the pipes can split at the "A" piller and burn out the CDL pump as it runs constantly, or the pump has failed totally. Not uncommon either.
Anyone else??
This is the free lunchtime tech line.
David
Old 10-01-08, 12:33 PM
Miket's Avatar
Anyone else??
It recently had a smack up the a4rse, could it be a pipe at the back that feeds the rear tailgate.
AK 427 FOR SALE
AK427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Old 10-01-08, 12:34 PM
Clarkson's Avatar
Speed junkie
Oh Yes,the pump is fitted in the rear quarter!
David
Old 10-01-08, 12:38 PM
Miket's Avatar
Which side.
AK 427 FOR SALE
AK427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Old 10-01-08, 12:42 PM
Clarkson's Avatar
Speed junkie
Which side.
O/S/R!
Pull the trims back and see if its broken,maybe the bodyshop has not fitted the vacuum pipes.
David
Old 10-01-08, 12:43 PM
Miket's Avatar
O/S/R!
Cheers mate, drink due at the Classic
AK 427 FOR SALE
AK427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Suspected blown head gasket Nick S General Cobra Discussion 51 11-05-08 10:22 PM
Head gasket sealant Sidecarbod General Tech Tips & Questions 2 09-05-06 12:56 PM
Composite head gasket RV8 3.5 martin_t Engine Tech Tips & Questions 8 23-04-06 05:15 PM
Head Gasket set for 302 Jason Engine Tech Tips & Questions 4 20-12-05 07:58 PM
Head gasket advice hfbradley01 Engine Tech Tips & Questions 14 10-02-05 06:12 PM
