| 17s on a pilgrim sumo can it be done? hi im 19 and my budget for a cobra isnt massive so ive decided on a pligrim but i love the look of the dax with 17s can the pilgrim body take 17s? |
| RE: 17s on a pilgrim sumo can it be done? Sibley I wouldn't recommend 17s on a Sumo, a friend of mine put them on and the ride was terrible, you feel every bump and pot hole however you set the shocker adjustments. I would go for 16s and gain the advantage of the extra depth of rubber. 17s on Jag suspension is fine but not on Sierra or Granada.
__________________ AK 427 FOR SALE AK427 FOR SALE PistonHeads AK for sale Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
| RE: 17s on a pilgrim sumo can it be done? Hi, You say you're on a budget so before you start I would look into the cost of insuring the finished car. If you are under 25 it can be very scary ;( Real shame to build the car and then not be able to drive it. Cheers, Andy Mike; What's it got to do with Sierra/Granada suspension? Sumos’ don’t use Sierra suspension so it's Sumo suspension that is responsible. http://www.corporanda.com/cos-race.gif http://www.fierofactory.org |
| RE: 17s on a pilgrim sumo can it be done? Hi I built a sumo when I was 19/20 and was great to build even then. I fitted Dax side vents but 15 inchers at the time lokked fine. Electric blue paint and my own dash just to makw it different. I'll send a picture if you like? Insurance was not to bad at the time about £600 fully comp but we are talking 11 years ago. Good luck Graham
| RE: 17s on a pilgrim sumo can it be done? Andy (Grim Reaper) This extract is taken from the current Pilgrim web-site. SPECIFICATION - PILGRIM SUMO (SIERRA BASED). Chassis Multi tube perimeter frame in box section steel with sheet steel floors, tunnel and bulkhead. Galvanising option. Body. Unstressed GRP. Single piece tub with double skinned bonnet, boot and doors. Suspension,Front Fabricated double wish bones, Ford Sierra modified McPherson strut upright, inclined adjustable coilspring damper unit. Suspension, rear Semi trailing arms mounted direct to chassis, adjustable coilspring damper units. Steering. Sierra rack and pinion. 4.15 turns lock to lock. Brakes. Front discs, rear drums, servo assisted. Engine option:. Ford four cylinder, V6 Cologne, Rover or small block V8. Wheel, and tyres. 6 x 15" wheels fitted with (F) 215/60 x 15 and (R) 235/60 x 15. Dimensions Overall length. 12ft. 8ins. Overall width. 5fy 10 ins Overall height 3 ft. 1O ins. Wheelbase. 7 ft. 6 ins. Ground clearance. 5 ins. Weight. 17 cwt. (1900 lbs). ************************************************** ***************** The Pilgrim web-site might be out of date and they now don't supply Sierra based kits, but the car in question was Sierra 2.0 ltr based and the Granada based kits aren't much difference to the Sierra. Why don't you stick to playing with your dinky toys, instead of sticking your nose into my posts. The new member needs positive input, not the negative crap that you post. :} :} :} :} :} :} :} :} :} :} :} :} :} :}
| RE: 17s on a pilgrim sumo can it be done? cobra kev Well done MikeT,as you have built a sumo ,then i guess that you would know about the suspension.!! Keep up with the good advise (and knowledgable) help that you give that helps so many others.well done miket for advise well given.:tu :tu :tu :tu :tu
__________________ \"If Anything that i post on this site offends any person in any way possible,i categorically apologise unreservedly in advance as any distress or alarm or harassment was not my intention.I apologise wholeheartedly!!!!!\" |
| RE: 17s on a pilgrim sumo can it be done? yeah graham plz would love to see al the pics u have of that car as i to like the side vents from the dax if i have the ££ id get the dax with the Tojeiro De Dion chassis but cant have everything x( also could someone explain the Q plate thing ive heard so much about wot is this and is it a bad thing? thx for your replys guys rich |
| RE: 17s on a pilgrim sumo can it be done? The Q plate thing.... Brfore the days of SVA, all kit cars which did not retain the original vehicle chassis (floorpan) got a Q registration. Since SVA, you have the chance to get an age-related plate: All new parts means you can get a current year registration. Sufficient items off one donor car gets you a reg of the same year as the donor. Too many items from different donors means you get a Q. Note that re-constructed production cars (eg a good one made out of 2 or more damaged ones) also get a Q when re-registered, so this is where some of the anti-Q stigma stems from. With a non-Q registration, you can do a cherished transfer of a number the same age or older than the donor, but no newer. With a Q, you cannot transfer plates (at the moment) but there are plans to make "Cherished Q" plates available in the near future. Hope this helps, Simon
| RE: 17s on a pilgrim sumo can it be done? Hello , and welcome. I have 17s on my pilgrim sumo and the ride is fine, a little hard maybe but it's worth it because they look so much better. Steve :tu |
| My Old Pilgrim Sumo | Miket | General Cobra Discussion | 8 | 22-11-07 10:05 AM |
| Jag based Pilgrim Sumo- How many? | Chimeara | General Cobra Discussion | 14 | 30-03-05 04:04 PM |
| Pilgrim Sumo MK3 | gareth08 | Pilgrim Sumo Technical Questions | 3 | 02-01-03 08:44 PM |
| Pilgrim Sumo | Bob | General Cobra Discussion | 5 | 07-11-02 08:37 PM |
| The Pilgrim Sumo | sprok | General Cobra Discussion | 7 | 19-04-01 05:54 PM |
