Old 07-03-08, 07:34 PM
bitsilly bitsilly is offline
Any problem here for harness mounting for SVA
I have twin roll over hoops on the Ram and had planned to put a harness mount in each side of each hoop a-la GD.
However the hoops are not central to the the drivers head a-la GD!
The best option I can see is to mount both harness ends in one side of the hoop (the one nearest the centre of my head). The question is has anyone done this before for SVA.
The only reference I can find to offset rules is that the straps shouldn't fall off ones shoulders.
So can anyone see any issue with this method before I crank up the drill?
Old 07-03-08, 07:44 PM
pete175's Avatar
pete175 pete175 is offline
Hi i have a ram with harnesses my car was passed with no modifications, ill take a photo for you tomorrow and ill post it to you
Peter
Ram SC
Ford Cleveland 351c V8 small block www.cobraclub.com/gallery/showgallery.php?cat=500&ppuser=6148
Old 07-03-08, 07:46 PM
chedz's Avatar
chedz chedz is offline
one issue, won't it look a bit odd? I like a bit of symmetry myself.
How about something like I did. I fixed it in the centre of the hoops on the body. I'm not sure of a RAM as space in the boot like a sumo but anyway...........
I made these brackets:
http://homepage.ntlworld.com/chedzoy/cobra/bracket2.JPG
they were then fitted in behind the seats like so:
http://homepage.ntlworld.com/chedzoy.../brackets3.JPG
(this picture is the original design before I beefed them up considerably)
Then fitted an eyelet at the top with a grommet like so:
http://homepage.ntlworld.com/chedzoy.../brackets4.JPG
this picture demonstrates my cock up, I have headrests which is not good with this design, but does show the way the strap fits on.
http://homepage.ntlworld.com/chedzoy/cobra/fcp/cob5.JPG
Next winter I plan to remove these 3 point harnesses and replace with 4 point with the anchor points either side of the head rest, but not just now.
hth
Graham
Old 07-03-08, 08:10 PM
Pete, I the only way I could get it thru with no more mods and below the lip is if the seats I get are very low and I fit inertia reel for the sva. Thanks for the offer of the photo but I think mine is an older chassis, all the chassis work for the roll over bars was my own creation (in order to get the roll bars braced etc so as to be deemed strong enough). But many thanks and I may get back to you on 35,836 other questions about Rams and SVA! I thought I was alone!
Graham, would you believe I considered that about a year ago and completely forgot it! I recon that is a much better solution. Many many thanks.
Result!
harness mounting bollo# bitsilly General Cobra Discussion 5 21-05-07 02:59 PM
Harness mounting bracket bluetoon Pilgrim Sumo Technical Questions 6 27-02-07 11:59 AM
Which Harness? kevchard General Tech Tips & Questions 8 18-02-07 03:43 PM
Harness Eye Bolt Problem madjohnny DAX Technical Questions 15 03-09-06 03:22 PM
Harness Martin427 General Tech Tips & Questions 4 16-05-01 07:50 AM
