| Front Suspension too soft on Pilgrim Sumo MkII Hi, I recently bought a MkII Pilgrim and following a trip to wales over the weekend, I suspect the front suspension (Cortina) is too soft. I've read that the original build used 80% rated springs, but I'm not 100% sure if that's the case. The tyres are catching on the outer arches when going over sever bumps, or under heavy braking. Solutions I have looked at are winding up the spax dampers (done with no improvemet) adding spring assistors (can't find any with a 12mm spring to spring gap) or adding new uprated springs. Has anyone come accross this problem in the past, and if so, what's the best solution to oversome it? Simon |
| Hi, from what I believe, the front springs are the softer Cortina springs. I spoke to Pilgrim yesterday who suggested that the early MKII kits had 220lb springs and suggested I change to the later mods for this kit which are either 280 lb or 300lb 11.5" long rather than the 12.5" which are on now. However he said he had none in stock and was unable to suggest a manufacturer of this type of spring. I would imagine this is the better route to take rather than coil overs due to the re-inforcements required. If anyone knows of a manufacturer of cortina springs, it would be a great help. Thanks Simon |
| Try tony at South Yorkshire Springs, he will make anything. Lynda |
| Forgot the phone number : Tony 01709 375375 |
| Cheers Lynda - message left on answerphone for Tony to get back to me Si |
| Pilgrim Sumo Soft Top | MARK ASH | Newbies | 3 | 30-01-08 07:29 PM |
| Pilgrim Sumo - suspension problem | janandchris | Pilgrim Sumo Technical Questions | 44 | 28-05-07 11:27 PM |
| sumo front suspension | stevem | General Cobra Discussion | 21 | 27-04-06 09:10 AM |
| Sumo FRONT suspension set up | Kevin W | Pilgrim Sumo Technical Questions | 1 | 24-01-06 02:47 PM |
| Pilgrim Sumo Soft-Top Fitting - Help ! | PeteV | General Tech Tips & Questions | 3 | 28-12-01 05:56 PM |
