| Running Gear A question asked before no doubt But opinions change Im sure. How much would you think I should need to spend to recon my own Jag running gear. Id not touch the diff (get that one done professionally). ((all in cost)) Also with a 302 with the Edelbrock performer package Im told Id be best off with a P/lock diff, yey or nay? I dont mind doing the donkey work if it saves enough cash. Thanks for the input. Andy R Proper Planning Prevents Piss Poor Performance!
| RE: Running Gear Rob, Thanks for that, car is mainly for street use with maybe the odd track outing. cheers Andy R Proper Planning Prevents Piss Poor Performance!
| RE: Running Gear Andy, I recon'd my front and rear Jag suspension back in 1992 and though I cannot recall the numbers in detail I do recall buying small carrier bags full of small parts and walking away with significant bills each time (hundred of pounds) - I replaced all moving parts pretty well throughout - bearings, spindles, and internal parts on the brakes (pistons and seals) and all u/j on teh drive shafts and had the diff reconn'd by a specialist (Eddy Reece at Wards). If I were to do it again I would cost very carefully all the current prices for parts versus buying complete units ready done from Eddy. I don't believe you save much if you do it yourself. The only way to make rreal savings is to not do stuff.
| RE: Running Gear Andy, I've just looked at doing exactly that when I ordered my Dax, after doing some calculations it worked out about £200 dearer to buy the non-assembled rolling chassis with everything already re-con'd for me. I thought the extra money spent just means I can build up the chassis that little bit quicker. IMHO Regards Michael |
| RE: Running Gear >A question asked before no doubt But opinions change Im >sure. > >How much would you think I should need to spend to recon my >own Jag running gear. Id not touch the diff (get that one done >professionally). ((all in cost)) > If you don't use a Power lock then you will be spending about £1200 to do a full proper job including buying the axles.
| RE: Running Gear Andy Dave is 100% correct, I spent £900 on parts to re-con and £250 for the axles. I don't know what Ward's charge for the fully re-conned units, but I would certainly not go through the hassle of doing the job again, my advice buy from Ward's. Dave, out of interest what is the retail price of all the re-con parts from Ward,s?
| XJ6 running gear | martin_t | General Tech Tips & Questions | 10 | 26-12-06 11:09 PM |
| Ford running gear | Harry-G | General Tech Tips & Questions | 11 | 23-12-06 09:24 PM |
| Jag Running gear | rlagden | Newbies | 12 | 02-11-05 12:16 PM |
| Cobra running gear | dinosoar | General Cobra Discussion | 24 | 07-11-04 05:28 PM |
| Running Gear | Andy302 | General Cobra Discussion | 4 | 17-04-03 10:27 PM |
