Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
  1. #1
    Noel's Avatar
    Noel is offline Technical Director
    Join Date
    Mar 2006
    Location
    Worcester Park, Surrey
    Posts
    3,902
    Fuel Consumption
    Just been down to Devon for the SW Meet and thought it was about time I bit the bullet and verified what fuel consumption I could get. I have always advocated that it should not make any difference what it was, if you are worried about fuel consumption..... get a hybrid. But anyway, I was shocked.......
    Just over 200 miles each way, M25, M4 and M5 with some "A" roads at each end and a couple of water/fuel stops in each direction. Kept to 70ish the majority of the time, stretching the right foot occasionally , with the engine running at approx 2400rpm when on the motorways.
    journey down.......19.7 mpg
    journey back........20.1 mpg
    that's on a SBC 383cu in with an Edelbrock 600cfm carb
    I bet an LS would have trouble matching that and I think says a lot for Jez and Ian at British American Engines
    I could nearly use it as a daily run-around , but don't get me wrong, I can still make that fuel gauge move like a tacho when I'm having fun
    Noel
    Sumo,
    BAE 427ci 560BHP Dart SBC / Edelbrock Thunder 800cfm.
  2. #2
    CycleSi is offline Mechanic
    Join Date
    Jun 2004
    Location
    Hazlemere, Bucks.
    Posts
    290
    Noel,
    You're letting the V8 side down with that 'modern fuel efficiency' - a maximum of 8 mpg is acceptable.
    You clearly need to have another 'roadtrip' with me.
    Off now to increase my carbon footprint courtesy of some high octane petrol and nitrous !
    CycleSi
  3. #3
    Noel's Avatar
    Join Date
    Mar 2006
    Location
    Posts
    3,902
    Quote Originally Posted by CycleSi View Post
    Noel,
    CycleSi
    LOL.....you're right, I would never see double figures when I'm out with you
    Noel
    Sumo,
  4. #4
    chedz's Avatar
    chedz is offline Chief Engineer
    Join Date
    May 2005
    Location
    Near Guildford, Surrey, England.
    Posts
    1,456
    Noel, that's impressive, about the same as my 3.5 around town/lanes.
    Do you know how/what the guys at BAE did to tune up the carb? Did they use lambda probes on the rolling road when they built it or do they just "know" what setup for the carb for an engine of that spec?
    Pete and I are about to do some work on fine tuning carbs and are "investing" in some kit, just wondered what the pros use?
    cheers
    Graham
  5. #5
    Noel's Avatar
    Join Date
    Mar 2006
    Location
    Posts
    3,902
    Don't laugh, but Jez use's his eyes To quote "if your eyes don't water when you start her up......it's too lean"??????
    Obviously he has years and years of experience and just "knows" when it sounds right. He sets the timing with a strobe and then the mixture by experience.........sickening
    I have a gas analyser if it's of any use?
    Noel
    Sumo,
  6. #6
    Purple AK is offline Pit Babe Magnet
    Join Date
    Aug 2011
    Location
    East Sussex
    Age
    61
    Posts
    14,967
    Must be the SW air Noel Seriously though, I always get 20+mpg on the long runs. 29mpg was my best effort
    AK427 351Cleveland T5WC
  7. #7
    KevinW's Avatar
    KevinW is offline Driving God
    Join Date
    Feb 2007
    Location
    Hants
    Posts
    5,451
    I talked to Mike Huddard about mpg and big blocks sometime ago.
    He told me that a 390FE properly set up should see in excess of 20mpg on a long trip.
    Hopefully he'll be along to confirm that.
    Kevin
    Crendon Chassis No.49
    Huddart FE428 + toploader
    486 ft lb / 491 HP on the brake
    460hp with Turkey Pan fitted.
    http://www.cobraclub.com/gallery/sho...hp/photo/8027/
    http://www.xtranormal.com/watch/6977111/
    Replica FPSB. Not listed in the Shelby Register.
  8. #8
    legend is offline Head Mechanic
    Join Date
    Oct 2005
    Location
    Costa Del Aldershot, Hants
    Posts
    813
    Kevin, I hope Mike does confirm that but I doubt it with Tony 'LEADFOOT' driving it.
    The Yellow Crendon 427SC, 448 FE Ford & Tremec TKO600.
    Polishes to date = 0
  9. #9
    runt's Avatar
    runt is offline Chief Engineer
    Join Date
    Jan 2006
    Location
    Romford, Essex
    Posts
    1,692
    So.. my favourite engines from the Golden Age of Motoring are..efficient, too.. I take it Mike wasn't referring to a 390FE pulling a T-Bird along..?
    My Ford Windsor probably wouldn't be so bad either.. if I didn't keep using all the go-juice flooding it on cold starts!
    Paul.
    DB REPLICAS DAX no. 106
    'JOHN WOOLFE black'
    HUDDART FORD 351W, 393 ci
    Doesn't just accellerate.. bends time..
  10. #10
    Noel's Avatar
    Join Date
    Mar 2006
    Location
    Posts
    3,902
    Quote Originally Posted by Purple AK View Post
    That is SERIOUSLY impressive Chris
    Noel
    Sumo,
  1. Fuel consumption for Chevy 350
    By martin_t in forum Engine Tech Tips & Questions
    Last Post: 09-02-06, 10:13 PM
  2. FUEL CONSUMPTION
    By chiffer in forum General Cobra Discussion
    Last Post: 23-03-04, 10:55 AM
  3. Fuel Consumption
    By Ian XII COB in forum General Cobra Discussion
    Last Post: 11-04-03, 05:53 PM
  4. Fuel consumption
    By Stefan in forum General Tech Tips & Questions
    Last Post: 05-04-02, 12:40 PM
  5. Increase performance and cut fuel consumption by 29% for les
    By agwebsites in forum General Cobra Discussion
    Last Post: 14-03-02, 02:23 PM
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
