| 500 CFM Question. Is a 500cfm carb big enough for a Ford 302 with full Edelbrock performer kit? Used Motor math and the formula under tricks & tips etc to work it out at 5,500 rpm. Anyone running a 500 or 600 on thie engine with stories to tell? Cheers guys Andy R Proper Planning Prevents Piss Poor Performance! :7
| RE: 500 CFM I think the carbs are matched to the engine by a specific formula which calculates the cfm,im sure some of the guys here will know this. I have a 500cfm carb fitted to my 302 mated to an eidlebrock torker 2 inlet recommended to me by brian at roadcraft uk who said this was the baby for me
| RE: 500 CFM Carb theory is quite straight forward. The engine need air for combustion. The higher volume and rev. the higher the need for air. There are other aspect that will make a difference like volumetric efficency (VE) and manifold caracteristics. The most important thing is to realise the difference between a steet engine and a race engine. What works on the track might not be so practical in a general traffic situation. Street engines must performe over a much wider spectrum and the easiest fault you might do if you try to mimic the race engine is to go for a too large carb, because it will make your car bog! You can compensate with either a longer accellerator pump shot and/or more fuel shot if you are slightly over-carbed. If you are grossly over-carbed you will NEVER get the needed vacuum signal to the boosters! That's why you should calculate the maximum need for your engine, multiply with VE, and pick a carb based on that CFM need (no more and no less). Spread bore and vacum secondarys will help drivability and fuel consumtion...
__________________ When you earnestly believe you can compensate for a lack of skill by doubling your efforts, there\'s no end to what you can\'t do! |
| RE: 500 CFM >I think the carbs are matched to the engine by a specific >formula which calculates the cfm,im sure some of the guys here >will know this. Taken from the Holley web site: Engine Size (CID) x Maximum RPM / 3456 = CFM @100% Volumetric Efficiency EXAMPLE: 350 CID X 6000 RPM = 2,100,000 / 3456 = 608 CFM Approximately 608 CFM would be required for this engine. However, most street engines are capable of achieving only about 80% VE; a modified street engine with ported heads, headers, good intake and carburetor can achieve about 85% VE; a fully modified race engine can achieve 95% or greater VE. The CFM number arrived at with this formula must be factored by this percentage.
| RE: 500 CFM Thanks to all. I didnt want to over fuel the thing! Andy R Proper Planning Prevents Piss Poor Performance!
