| is the body distorted (common webber problem if over tightened to manifold) take it off and see if it goes free; (too) thick gaskets are usually the culprit.
| I did try replacing the spring with a slightly stronger one.....but then I couldn't press the throttle smoothly , you would press harder until suddenly the pedal would jump down (not good, especially in damp conditions!!)
__________________ "...55mph!!....slow enough to make you think your safe.....but fast enough to kill you!..." : Gumball Rally 1976. Jan & Chris. MK II Sumo RV8 |
| Can you remove the cable again and try moving the carb linkage through it's full travel? If that sticks then you can point the finger at the carb itself. I fitted a Weber 500 to my Land Rover and used a bicycle brake cable as an accelerator cable. It stuck all the time and was not smooth at all giving a very jerky feel to the pedal. I brought a Land rover 110 V8 accelerator cable and it was as free as a free thing, and had the right fittings on the ends. Transformed the Land Rover. When I built my Dax I used the same cable but had it modified by Venhill Cables to lengthen it a bit. Still works and fits perfectly. Craig.
| sticky clutch | pcoghlan | Gardner Douglas Technical Questions | 18 | 01-04-08 02:36 PM |
| Sticky stuff | plod | General Cobra Discussion | 6 | 28-08-07 11:53 PM |
| Sticky Thread | catchpic | Feedback, Membership and Help | 1 | 02-06-05 10:52 PM |
| sticky clutches | sideoiler | Snake Watch & Industry News | 9 | 19-05-01 04:43 PM |
| Sticky Clutch | Mike | General Tech Tips & Questions | 2 | 08-05-01 11:50 AM |
