Old 17-09-03, 07:00 PM
Electric fuel pump Big Block Ford
I have a problem with my 429 motor regarding fuel supply, I cannot get the mech pump to work correctly(stripped and checked eccentric cam which is ok)anyway I need an electric pump to supply fuel at about 5 psi to get the motor shook down but dont want at this stage to buy an expensive one as I still intend to go mechanical.Any suggestions as to a suitable pump cheap and readily available for the interim??? The problem with the mechanical pump is, at present it wont fill the in-line filter so is not supplying enough to keep her running. Thanks in anticipation. Dave Keane :} x(
Old 17-09-03, 11:12 PM
RE: Electric fuel pump Big Block Ford
You can normally get the motor running by rigging up a petrol can above the engine and relying on good old gravity to feed the carb with juice. Either that or have you tried an old washer bottle motor ?
Tony
Old 17-09-03, 11:44 PM
Tony, thanks for the reply, I have tried gravity feed no luck!! the washer bottle motor theory is interesting. Dave
Old 18-09-03, 10:15 AM
Banned
Contrary Mary
You will have to siphon it out the can or bottle and take the chance of a gob full (drank loads!)or chuck some down the hole and it will run for a short period Eric.:9
Old 18-09-03, 11:21 AM
russell_ram's Avatar
Club Treasurer
Dave,
Sorry but the washer bottle motor theory will not work. The rubber in washer bottle pumps is not compatable with fuel - it will swell and stop the pump running. I tried this as an emergency roadside fix many years ago when the mech fuel pump cam failed on my Ford V6, so I tried to re-route the fuel feed via the washer pump - worked for about a minute before the pump siezed. Ended up working the pump lever by hand to fill the carb, then driving/rolling as far as possible on a carb full of fuel. Took ages to do the ten miles back to home but got there eventually!
Russ
Old 18-09-03, 12:59 PM
Ah Russ,
That was because you had a Ford washer motor, you should have used a Chevy washer motor.......................
( I found an old Marina/ Ital pump worked really well....)}(
Tony
Fuel Pump - Manual or Electric V8 BJC General Cobra Discussion 8 25-10-07 01:18 PM
Where should my Electric fuel pump be located Davecw000 Pilgrim Sumo Technical Questions 9 05-05-06 03:14 PM
Chevy V8 Electric Fuel Pump bogster DAX Technical Questions 11 10-12-05 04:50 PM
Correct Electric Fuel pump? Steve Faithful General Tech Tips & Questions 12 30-10-05 01:19 PM
Fuel Pump-Electric or mechanical? Dax SC General Tech Tips & Questions 13 05-09-02 11:39 AM
