Old 17-10-03, 07:08 PM
Andy302's Avatar
Storing a crankshaft
hi guys,
now that I have my crank I intend to coat it in oil and seal it in a bag.
i have been struggling to find a suitable type of bag that A0 can be sourced locally and b) wont cost the earth in delivery charges.
Do you think a strong bin bga would do. Maybe Id wrap in int one, seal it then add another. the whole crank will then be returne to its box so snags wont be an issue.
Any thoughts?
cheers
Andy
Andy
www.andysgd427.blogspot.com
Old 17-10-03, 07:13 PM
simon's Avatar
RE: Storing a crankshaft
Sounds good, just make sure it's all covered with oil, even the oilways through the crank.
Old 17-10-03, 07:19 PM
Andy302's Avatar
Simon,
thanks!! Ill get out the oil, will WD40 do or should I go for something a bit heavier?
cheers
Andy
Andy
Old 17-10-03, 07:42 PM
Andy,
WD and a bin bag will be fine.
Shane 351W
Old 17-10-03, 09:02 PM
Exactly what I used over a dank and wet winter in a soggy garage - no problems. Duct tape the bag.
Old 18-10-03, 11:07 PM
I grease the journals and then spray the rest with oil and wd40. Put it in a bin bag and spray wd 40 into the bag, then tie it up and seal the bag with tape. Leave to grow and see if you have a stroker come spring
Boost it, I do!
Aka Boosted LS1, Boost it
Crankshaft Bearings martin_t Engine Tech Tips & Questions 2 30-05-06 08:29 PM
Help with Crankshaft choice... Andy302 General Tech Tips & Questions 13 03-10-04 05:27 PM
Crankshaft Spigot Bush Phil McCann Engine Tech Tips & Questions 7 26-03-04 11:33 AM
Storing an engine. Andy302 General Tech Tips & Questions 2 16-07-03 07:45 PM
Storing the hood....... geoff Pilgrim Sumo Technical Questions 3 11-06-03 12:52 PM
