| Brake Pipes Hi guys Some advice please on brake pipe size.About to start on the braking system, Sumo/Granada/discs F&R. What size brake pipe should I use. Who are the best people to supply fittings, do motor factors or autospares places do them. I need locknuts for the Pilgrim supplied flexi's, fittings to connect to the said flexi's, tee piece with fittings and am contemplating a compensation valve. Any advice gratefully received Thanks Phil:} |
| RE: Brake Pipes Hi Phil, Most good motor factors can supply brake pipe and the various sizes of pipe nut, depending on your thread sizes. I recommend you buy a coil of copper brake pipe 3/16" is the standard size. You will also need a flareing kit to make up the ends, it's quite simple really, try a few practice ones first before doing the actual pipes. A flareing tool will vary in price so I guess it depends whether or not you'll ever use it again after you finish the build on how much you want to spend. I gather most Sumo's use a compensator valve. I recommend you use stainlees braided flexy hoses but make sure they are SVA compliant ones. One supplier I use is "www.thinkauto.com" :tu :tu :tu Good luck with your build http://www.woodoouk.eclipse.co.uk/Wales.gif Kev Davies Dax, 383ci Chevy Stroker, Tremec TKO South Wales
| RE: Brake Pipes Phil, As Kev says, go to a motor factor for the pipes and fittings. Tony Holmes told me that you only need the compensating valve if you use the Sierra setup with rear drums. I have a Sumo RV8 with Granada running gear and its fine without. Passed SVA 1st time so save yourself the aggro and do without,
__________________ Keith S Built a Sumo 3 RV8 Sold it to buy a 2000 Chimaera 4.5 |
| RE: Brake Pipes Thanks Kev/Keith I'll head out right now and procure the necessary bits. Cheers Phil:} |
| Brake pipes | servistar | General Cobra Discussion | 9 | 28-12-06 08:04 PM |
| securing brake pipes | Daxman | General Tech Tips & Questions | 14 | 03-06-06 10:56 PM |
| Brake pipes | JonnyT | DAX Technical Questions | 13 | 20-02-06 08:21 PM |
| Brake pipes | jeff | Pilgrim Sumo Technical Questions | 0 | 25-02-04 12:00 PM |
| Brake pipes | Shaney23 | General Tech Tips & Questions | 11 | 29-11-03 08:48 AM |
