  #21 (permalink)
Old 07-02-10, 08:19 PM
Clarkson's Avatar
Originally Posted by slogger View Post
Clarkson m8, it is all relative. The 'not a lot of cash' statement I mean. A guy I know considers himself nearly skint when he gets down to his last 4 million in the bank. He then embarks on the next money making project / deal.
When someone tells me they are skint, they don't have more than 100quid in the bank account. Lol
David
SRV8
New engine build, 388ci short stroke with TWM EFI injection,Bowtie block 4.125 bore, callies crank 3.625 stroke, scat 6' Hbeams, JE piston,Custom billet solid roller cam,Comp rev kit, Jessel belt drive, AFR heads 227cc, yella terra shaft rockers. Emerald ECU, wasted spark coil pack Ign.
http://www.youtube.com/watch?gl=GB&h...&v=IauqIQuOX0E
"Buy a Toyota, it drives itself"
  #22 (permalink)
Old 08-02-10, 08:28 PM
Z5Roadster's Avatar
Originally Posted by TonyD View Post
Alternatively go megasquirt on the engine, (utilising the OEM knock sensors if possible), get some decent exhaust manifolds made as BMW ones are truly awful and strangle the engine, tune it via a laptop and some spirited driving and you'll have a rather nice combination.
Best of luck,
Tony
Tony.
I have had a reply from megasquirt asking is there anything other than fuel & ignition we require the ECU to run. Can you please advise.
cheers Tom
Follow the Dream
Aluminium Body project now underway thanks the help of Paul C and Nic H Somerset.
  #23 (permalink)
Old 09-02-10, 01:30 AM
Originally Posted by Z5Roadster View Post
Tony.
cheers Tom
If they are asking, I'd certainly ask them to see if they can accomodate knock sensors, traction control, soft rev limit, cooling fan, road speed, oil pressure, revs, volts, amps and oil temperature. ( use the ABS sensors to run traction control system)
This would enable you to use one point to wire in dashboard.
To give you some indication of how clever the original BMW ECU is, it monitors each and every denonation to ensure it is clean and sharp. Any misfire and it closes down that one cylinder until the ECU is reset. This means that should you set off a bit sharpish when the engine is still a bit cold ( lets say a bit of childish showing off when exiting a pub car park) and a trace of unburnt fuel causes a miniscule backfire the the ECU will cut all fuel and spark to that individual misfiring cylinder until the ECU is reset.
Thus you can drive home for 30 minutes thinking " Shit, I've dropped a valve doing that burnout" only for the car to reset itself between stopping in front of the garge door and running it into the garage. Bastard.
Or, for example, if a hose comes off and the engine starts to overheat the ECU will configure the engine to use cylinders to cool itself, firstly by injecting more fuel and then secondly by cutting the spark and using alternate cylinders as heat pumps to cool the engine.
Then if you're too stupid to stop the engine , when it gets to 117 degrees celcius it cuts out completely and wont start until it cools to 80 degrees. Absolutely impossible to overheat. Hence its things like this which is why I like standard ECU's.
Megasquirt will never be able to emulate that degree of complexity but if you can get it to run using the standard BMW sensor package, plug into the standard engine loom and give you functionality into the future re boost / forced injection compatibility you won't go far wrong.
I'm looking at using megasquirt as a simple piggyback controller for an additional injector or two on a boost sensor which should be adequate for my turbo backyard engineering requirements. I've got all the standard functionality from the original ECU, ignition, knock sensors, open/ closed loop fueling/ spark etc.
Good luck on making your own "aluminum" body, if you do one there may be orders waiting in the wings.....
Tony
Supply by blagging, engineering by bodge......
  #24 (permalink)
Old 14-02-10, 11:33 AM
Z5Roadster's Avatar
Thumbs down Front suspension problems
At the moment I can't sort out how to get away from the top rocker idea without major redesign to the lower end of the leg.
[pic]http://cid-6e9208cc392fdb02.skydrive.live.com/self.aspx/cobra%20build/IMG%5E_1271.jpg#resId/6E9208CC392FDB02!248[/pic]
because the leg has to revolve say 90deg can't see how I can get the coilover secured at the bottom??
Follow the Dream
  #25 (permalink)
Old 14-02-10, 11:38 AM
Miket's Avatar
Extremely Senior Member!!
IMG_1271.jpg - Windows Live
Try this
Mike
Cobraless
With Age Comes Skills, It's Called "Multi Tasking"
I Can
Laugh, Cough, Sneeze, Fart and Pee all at the same time.
  #26 (permalink)
Old 14-02-10, 12:03 PM
Z5Roadster's Avatar
Originally Posted by Miket View Post
Thank you young man, whats the date for the March Kenn meet. Is the 1st Sun every month.
cheers Tom.
Follow the Dream
  #27 (permalink)
Old 14-02-10, 03:40 PM
Miket's Avatar
cheers Tom.
Hi Tom
Are you not on our Area Rep's email list if not PM me your email address and I will forward it to Chris and you will be updated as to where the meets will be.
As in 2009 we are moving around for each meet, the next one is at the Fishermans Cot, The Fisherman's Cot, Bickleigh, Tiverton, Devon, England - ensuite bed and breakfast accommodation in traditional historic and haunted inn in Devon
Here's the programme, venues to be updated
CRC SOUTHWEST
2010
MARCH 7th - FISHERMANS COTT
APRIL 11TH - ANDY LOVEDAY
MAY 2ND – BARRIE PIPKIN
JUNE 6TH –. STEVE AND NICKIE
JUNE ? CULMSTOCK ?
JULY 4TH STEVE AND DIANE
JULY ? DEVON/CORNWALL RUN?
AUGUST 1ST - ANT AND EM
AUGUST ? MT EDGECUMBE ?
SEPTEMBER 5TH - LESLEY AND JERRY
OCTOBER 3RD LAURIE AND CHRIS
OCTOBER 22ND KIT CAR SHOW
NOVEMBER 7TH - NEIL OAKLEY TREASURE HUNT TIN TOPS
DECEMBER 5TH
Mike
Cobraless
I Can
  #28 (permalink)
Old 03-04-10, 12:49 PM
Z5Roadster's Avatar
Update
Been a bit busy of late but things are still happening.
The chassis is on the back burner at the mo due to the ally body gaining momentum.
I have been offered the loan of a Southern Roadcraft Shell complete, from this I hope to be able to collect all the profile data and produce a wooden buck.
Have looked into whats about Laser measuring wise but without spending bucket loads its a none starter going down that road.
The best option is to build what they call a measuring bridge get the section data from that and turn it into Plywood profiles, these would then be pieced together progressively building up the finished contours
A long and slow process but something that can be flat packed when not in use.
Will post some pics once things start coming together.
Cheers Tom
Follow the Dream
  #29 (permalink)
Old 03-06-10, 09:45 PM
Z5Roadster's Avatar
Body Dimensions
Can anybody help with body dimensions.
I now have the Southern Roadcraft body, but I think the wheel base may be 91.5", I know that there are 92" w/b (Python) .
Also if someone can confirm the door length from upright to shut this may also help.
Thanks.
Follow the Dream
  #30 (permalink)
Old 20-06-10, 08:33 AM
Z5Roadster's Avatar
What the length of your DOOR this ones Southern Roadcraft which I think is now Magnum SRV8
I am of the opinion the 90" wheel base cars may be smaller, Please let me know with the make.
Thanks
Tom
Follow the Dream
BB code is On
Run To The Sun. Head Count nickmupp Events 0 05-07-09 03:16 PM
Hole in the head.... FOT Fast Engine Tech Tips & Questions 5 13-01-08 09:18 PM
Head Gasket set for 302 Jason Engine Tech Tips & Questions 4 20-12-05 07:58 PM
Head retraints jong General Cobra Discussion 9 02-12-05 09:13 AM
Head up display Robin427 General Tech Tips & Questions 8 16-11-05 08:50 PM
