Old 01-03-04, 01:54 PM
ford 302 spec
Folks
all you Ford 302 owners have you any advice on what spec I should be aiming for when I rebuild my 302. I'm looking for around 300 BHP.
Old 01-03-04, 03:07 PM
RE: ford 302 spec
Hi Rover
Its nice to see a Ford post for a change!
I bought my 302 from Brian at Repower in Sussex -
The spec of this engine is:
Ford 302 block
GT40 Head - cast iron
Compression ratio 9.0
Edelbrock performer RPM inlet manifold
Edelbrock 600 CFM Carb
MSD Ignition
Plus other bits.
Power guide 285 BHP 310 Ft Lbs
see www.roadcraftuk.cu.uk for full specs.
I must say that it is a very willing lively engine -Andy at GD was quite impressed when he drove it- and is fine at low revs around town.
Hope this helps
Stu Kaynes
Old 01-03-04, 03:08 PM
RE: ford 302 spec
Correction website should read www.roadcraftuk.co.uk
Old 01-03-04, 05:51 PM
Andy302's Avatar
RE: ford 302 spec
Hi,
Im soon to be starting a 302 rebuild (when my engine actually arrives!)
Anyway heres what Im going to do.
Seasoned 302 block, machined as required.
600 cfm Edelbrock performer carb.
RPM intake.
RPM heads 2.02 valves.
Keith Black pistons to give CR round 9.5:1
Eagle SIR5090FP rods.
New CAT crank.
New standard oil pump.
Now heres the important bit ( I hope!!) for driveability Im not using the performer RPM cam as its too lumpy, going for the comp cams 268H. Has a noticeable idle but Im told its not as bad as the performer RPM.
Comp cams lifters and timing gear set.
Im only short of the carb, cam, lifters, timing gear, pistons, oil pump and block!
Everyting else Ive got already. Big hint buy from the US, prices are very good!
Hope that helps & good luck.
Now watch someone say...Ah but if you.....!! :tu
Andy
Study filling up with bits, wife not so amused! :tu
Andy
www.andysgd427.blogspot.com
Old 01-03-04, 08:50 PM
RE: ford 302 spec
Stu
thanks for your reply have you any idea of the Cam that's in your engine. Do you know if the GT 40 heads are readily available.
Mark
Old 01-03-04, 09:09 PM
RE: ford 302 spec
Andy
Thanks for the reply, the dollar rate is what's set me off. The engine I have was a runner when I bought it it has a 600 holley and a Torker 289 manifold on it so i'm sticking with them to start. What i'm unsure of is the best comp ratio and the heads/ pistons to suit. It seems to get a decent comp ratio that you need to take some off the block
Old 02-03-04, 06:50 PM
RE: ford 302 spec
Mark
Sorry for delay in reply.
Camshaft is 0.480" lift.
Check with Repower for availability of GT40 heads. It seems that you can get a lot more HP if you port these heads.
I would also look into Edelbrock performer aluminmium heads - a bit more expensive though. Either of these routes should give you around 300BHP.
Orignal Cobra Spec Martyn-ak427 General Cobra Discussion 6 18-11-07 11:36 PM
GD Wheel spec chris m General Tech Tips & Questions 20 03-10-05 09:43 PM
Ideal Manifold Spec RV8 4.6 RV846 Engine Tech Tips & Questions 0 17-01-05 03:23 PM
What do you think to this build spec? red snake General Cobra Discussion 5 10-01-04 02:30 PM
Looking for Cobra spec Rover 4.6? russell_ram General Cobra Discussion 0 15-04-02 06:59 PM
