Old 07-03-04, 10:09 PM
effect of different oil filters ?
What effect does it have by not using the correct oil filter? for example there is very little clearance for the correct oil filter on my RV8 so I use anything else that will fit ie longer but smaller in dia.
Will this have a detrimental effect ?
Why are coopers oil filters recomended ?
Steve
Old 08-03-04, 01:46 AM
RE: effect of different oil filters ?
Different filters will have a different element surface area than the "standard" one.
The internal construction will differ too.
There's actually a large variation between manufacturers when comparing their filters for a single application.
There was a post on here recently, which showed some info on a range of filters. (for a Ford 5.0 I think?)
Basically a smaller filter will be able to trap less crud before it goes into bypass. Just bear that in mind when considering your oil change interval.
At 3000 miles on a decent engine there shouldn't be an issue.
Simon.
Old 08-03-04, 12:22 PM
I've had the same problem. After speaking to Pilgrim an old style CVH escort filter is the same thread and almost the same diameter - it's just about 1.5" shorter which is enough to fit against the chassis.
Same advice i had been given though, you'll need to change the filter more often due to the surface area / capacity.
Jon
Old 08-03-04, 05:56 PM
Banned
Steve, you can still get the shorter RV8 filter made by Mann, P6 I think!? Have the part number if required. In your case Steve I don't think the extra micron filtration will ever affect you or come to your notice, they are all a bit of a muchness. Worked for Crossland filters for a time which is a Lucas CAV company (not a lot of difference between the lot!) despite what it says on the packet! Eric
Air Filters JonnyT General Tech Tips & Questions 8 09-01-06 08:49 PM
LS1/SBC oil filters... anyone need any? Robin427 General Cobra Discussion 0 09-03-05 12:11 AM
'Hall effect' speedo sender roll control General Tech Tips & Questions 6 10-10-04 08:31 PM
Oil Filters Bigblock General Tech Tips & Questions 0 10-02-04 02:07 PM
Hall effect sensor millsd60 General Tech Tips & Questions 14 19-05-03 11:17 PM
