Old 30-03-04, 05:56 PM
Rover V8 Timing
Hi All,
Need help to get her started
Took the distributor off to paint it and painted over the marks I made. I know stupid. I have to reset the timing is there a simple way to do it. The distributor feed is connected to an electronic box with the coil piggy back style. No comments about the position{-} Any help would be appreciated. It's a new build, Ak, ready to put the tub on.
Many thanks
Huge.
Old 30-03-04, 07:31 PM
STEVE G's Avatar
RE: Rover V8 Timing
Huge
Turn the crank so the pointer is about 8 degrees BTDC then fit the dizzy so that the rotor points to the terminal in the cap that goes to No 1 Cylinder (front passenger side).If you've got fuel and sparks it should fire-up.Then you can time it proply with a gun,anywhere between 21 and 30 advance at 3000 revs with vacuum pipe off(and sealed)
Steve G {-}
GE427-Rover 281ci.(300+BHP)
Regards Steve G
Old 30-03-04, 07:44 PM
RE: Rover V8 Timing
You need to reset the static timing.
Forget about the coil etc- that sounds bog standard SD1.
Key question is, what sort of distributor have you?
If it is also bog standard ie lucas electronic, the method is all explained on page 68 0f Haynes manual- including a picture showing the relationship of the timing rotor and the magnetic pick up.
Email me your address and I'll send you a photocopy
David
Old 31-03-04, 06:53 PM
RE: Rover V8 Timing
Thanks Steve and David.
Got her up and running tonight after a bit of fiddling. Sounds great It has given me a boost to keep going.
Many thanks,
Hugh :tu :tu :tu :tu
Old 01-04-04, 07:06 AM
STEVE G's Avatar
RE: Rover V8 Timing
You cant be bad with engines if you understood my instructions.A great feeling when you firat here that noise,Yes?
Steve G {-}
Regards Steve G
Rover V8 Cam Timing steve.hills Engine Tech Tips & Questions 4 03-01-08 03:21 PM
Rover 3.5 ignition timing...my engine is rubbish! Sidecarbod General Tech Tips & Questions 40 10-04-06 11:00 PM
Rover Timing Rustynuts Engine Tech Tips & Questions 5 02-09-05 08:27 PM
SBC Timing - 2 timing marks on damper jonbillings General Tech Tips & Questions 14 09-10-03 07:37 PM
rover v8 timing markg General Tech Tips & Questions 14 28-08-03 10:27 PM
