Results 1 to 6 of 6
  1. #1
    windsor400's Avatar
    windsor400 is offline Chief Bottle Washer and Tea Boy
    Join Date
    Jun 2009
    Location
    wiltshire
    Posts
    114
    rear spring ratings
    Hi,
    We took our Cob to Combe on Sunday, with the Bristol Motor Club, and had an awesome time on the track, where was the 50mph limit of the pace car??
    Not complaining!! Cob performed brilliant on the track we seem to pull away from other Cobs on the straights and they caught us up on the bends!!
    We had to slow down on the chicanes as both rear inside tyre edges were rubbing the inner wings!! I think i need stronger rear springs at the moment i have 225lbs on the rear. any suggestions what weight i will need just for Track Days?
    Alan
  2. #2
    tonym's Avatar
    tonym is offline Driving God
    Join Date
    Apr 2004
    Location
    on the edge...almost falling off
    Age
    50
    Posts
    6,046
    Depends on which cobra replica you have??
  3. #3
    Russ-Notts's Avatar
    Russ-Notts is offline Mechanic
    Join Date
    Oct 2006
    Location
    Toton, Nottinghamshire
    Age
    39
    Posts
    402
    Alan,
    Four 225lb springs seems to be fairly common at the rear on a number of Jag based Cobra replicas. Have you tried adjusting the shock absorbers? A 5 minute job to turn up the damping on the shocks for the occasional track day. They can be returned to a softer setting for normal road use afterwards.
    Russ.
    1984 Dax Cobra.
    Rover 3.5 with Holley
    Jaguar 3.54 Powr-Lok diff.
  4. #4
    windsor400's Avatar
    Join Date
    Jun 2009
    Location
    wiltshire
    Posts
    114
    Hi,BIG TONE,
    Our Cobra is a AK 427 Gen 1.
    Hope this helps
    Alan
  5. #5
    windsor400's Avatar
    Join Date
    Jun 2009
    Location
    wiltshire
    Posts
    114
    Hi.Russ Notts,
    How many clicks on all 4 rear shocks would i start with and do i need to adjust the front shocks as well ?
    Alan
  6. #6
    Russ-Notts's Avatar
    Join Date
    Oct 2006
    Location
    Age
    39
    Posts
    402
    Alan,
    The number of clicks will depend on the manufacturer of your dampers.
    For a normal road setup the back dampers will generally be somewhere approaching the mid-point setting between fully soft and fully damped. The front dampers will be set slightly harder than the mid point. Front damping always set harder than at the rear. Then it's a case of road testing and adjusting until you find the hardest setting which is still comfortable. For a track setup you increase the damping all round, again fronts harder than the backs.
    Before you start making adjustments it's probably worth recording a note as to what each damper is currently set at by counting the number of clicks back to the fully soft position. Then counting the number of clicks it takes to adjust the damper to full hard. You then have some reference for your current setup and a 'clicks scale' for where the mid points etc are for your dampers. e.g my Gaz shocks are 46 clicks soft-to-hard if I recall correctly.
    Russ.
    1984 Dax Cobra.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
