| Re: More EFI questions don't know flow rates, but standard rover and jag efi pumps are fine, and pretty good value from motor factors. BTW these pumps don't suck very well, so must be fitted near to and on a similar level to the fuel tank outlet. If you use flexible fuel hose as I did you MUST only use hose rated for fuel injection as the standard fuel hose won't stand the higher efi pressure for very long with potentially disastrous consequences. For preference I use oetiker hose clamps instead of worm drive as they are more forgiving and don't cut into tjhe pipe as much. Kev |
| Re: More EFI questions Tony, depends on what sort of power your ultimatly going for, but if your after a standard setup then get a standard pump from RPI, around £75. If your going for more power go for something like a Vortech TRex (VOR-8F002-265) 50Gph at 70psi from Summit racing, around £120 Phil
| A few questions | angus99 | Newbies | 13 | 21-11-06 09:18 PM |
| SVA questions... | TheUnixKid | Pilgrim Sumo Technical Questions | 4 | 05-10-06 11:13 PM |
| Sva questions | adricar2 | General Cobra Discussion | 4 | 31-08-05 06:09 PM |
| Hi, a few questions. | spwells | Newbies | 38 | 19-06-05 09:26 AM |
| Questions | graham | General Cobra Discussion | 5 | 04-02-02 09:07 PM |
