Old 11-06-04, 03:34 PM
Andy302's Avatar
Help with Fuel Injection.
Working through the fuelling options for my motor Ive found myself thinking about aftermarket fuel injection for my 1971 Ford 302. Ive looked at the options I could easily find...
1) Edelbrocks proflo system {v. expensive}
2) The Holley commander 950 (thats for the 5.0 302 {does that mean the latter engines?!} will it work on a 71 302?
and then I spoke to someone about LPG and he recommended getting a Holley injection manifold and some Jag injectors etc....... He also spoke about Emerald? injection ecu's and Ive heard of the megasquirt (is that right?!?)
Any help will be appreciated because Ive not yet brought a carb but I do have a performer rpm manifold which I could adapt or sell.
Are there any other systems around, is it easy, and importantly is it expensive and worth the effort?
Andy
Andy
www.andysgd427.blogspot.com
Old 11-06-04, 05:56 PM
Re: Help with Fuel Injection.
Andy,
Some interesting systems and info. over here......
www.kinsler.com
Shame they are not over here!
GUMBALL
Too many idiots, not enough villages!
Old 11-06-04, 06:32 PM
Andy302's Avatar
Yeah, nice manifolds!!
Ive now seen the Holley commander 950 TBI system which will fit onto mu intake I guess. Any opinions anyone?
Andy
Old 13-06-04, 11:27 AM
JamesP's Avatar
I've done the trawl through the aftermarket injection systems as well.
At the moment the Megasquirt only controls fuel not spark, although they are working on a Squirt n spark system for future release.
Kinsler systems look great until you see the price.
Edelbrock pro flo systems look good, I understand they are limited in the size of the injectors they can contol so are only good up to a certain HP, not sure if this is right, I know Rob was using this system on his supercharged GD and that made more than enough power for most people.
I'm going for the Holley 950 Pro system with wide band O2 controller. There's some great support online under the Fuel Injection forum on www.chevytalk.org, the moderator, Doug, works for Holley and if he can't fix it then it can't be fixed.
As for my system I found a cheap manifold, throttle body, fuel rails and 36lb injectors on eBay - an Accel ProRam system, which I'm going to wire up to the Holley ECU (the Gen VII Accel system looks great and is very sophisticated but is very expensive (another $1000 on top of the Holley system at least)
James
Megasquirted 383 SBC built but yet to start.
Dax De Dion chassis safelty in garage.
Permission to spend money in March - rolling chassis here we come
Old 13-06-04, 11:32 AM
Andy302's Avatar
Thanks for all the replies.
After looking round Ive decided to stick with a carb setup for now and then put injection on the list of upgrades for the future.
Only knows if Ill regret it later!!
Andy
Old 13-06-04, 11:46 AM
James,
just to let you know Megasquirt does control spark as well, been running it on my car since last year. MS2 is out very soon which will have a processor twice as quick and is an easy upgrade from MS, just plugs into the old processor hole. This will also have spark control with temp compensation.
Phil
5.0L TVR EFI Power
Old 16-06-04, 11:41 AM
JamesP's Avatar
Phil
Thanks for the the notice, it's going to be a while before I have to by the ECU, still just building the engine then have to build the car, at this rate it'll be years before I get to start her up, I'll have another look on the Web and catch up on developments.
James
Fuel injection without swirl pot? Scottieb Pilgrim Sumo Technical Questions 1 06-02-07 05:59 PM
Air/Fuel & Injection mikey General Tech Tips & Questions 0 06-09-05 08:44 AM
rv8 fuel injection markg General Tech Tips & Questions 3 19-05-04 06:57 PM
Fuel Injection fuel pump problem. Poohbear Engine Tech Tips & Questions 20 11-05-04 11:53 AM
Fuel injection snakebite General Tech Tips & Questions 2 26-01-04 04:31 PM
