| Re: Ball joint endcap Thanks guys It`s just 1 end cap I need (with the 4 bolts if possible) They are not handed as far as I know both sides are the same It`s part number 19 here... http://www.sngbarratt.com/UK%20PDFs%...Suspension.pdf I could probably pick up from Donnington if either of you are going If not - I will obviously cover postage Thanks Paul
| Re: Ball joint endcap Rich Donnington will be fine thanks I am back home in Holland now and my chassis is in the UK so I can`t do anything with it until I come back over in September. I will email you nearer the time. Thanks again
| Re: Ball joint endcap paul If your wishbones have had sealed joints fitted, then the steel collar that the older style rubber dust guard fits onto, will have been knocked out. Hopefully they might come in your recon kit. If not you will have to buy new ones as its almost imposible to remove them intact, as the rust fairy has been on overtime with them Rich |
| Re: Ball joint endcap Quote:
You`ve lost me here - which steel collar is this? Item number 20 on the following page is the same as the rebuild kits I have....... http://www.sngbarratt.com/catalogue.html Paul
| Re: Ball joint endcap paul, It is descibed as 'ballpin spigot' under item 20. It is a metal collar that fits in the top of the large hole in the hub carrier upright, that the ball joint sits in. Then the rubber dust guard goes over the ball pin and is clipped to this collar. Rich |
| Ball Joint Thread? | wilf | General Tech Tips & Questions | 10 | 04-11-07 07:28 PM |
| Top ball joint rubber ! | cliffords | General Tech Tips & Questions | 3 | 01-07-06 12:48 PM |
| nut size on ball joint | Cobra power | General Tech Tips & Questions | 2 | 11-03-06 01:49 PM |
| bottom ball joint | jeff | Pilgrim Sumo Technical Questions | 4 | 13-05-05 11:42 PM |
| ball joint problem. | chris m | General Tech Tips & Questions | 6 | 17-12-02 08:50 AM |
