| Re: Carpet on Centre Tunnel 6" nails worked for me!! Just try good old Evo Stick (contact adhesive) you can get it from Wickes about £5
__________________ Cheers !! David |
| Re: Carpet on Centre Tunnel I used some cotton type padding between the tunnel and the carpet to help the carpet flow around the tunnel. It just helps to fill out the baggyness (not really a good word) which will always get because of the tapered shape. with a decent upholsterey glue I've had no problems.
| Re: Carpet on Centre Tunnel Brian, This is the only problem I have left after the SVA in exactly the same place as your (and my rubber door seals) Have tried Grippa spray which stuck well but finally gave up on Wednesday so have now bought a large tub of Evo Stick which I will use tonight. |
| Re: Carpet on Centre Tunnel You may find that you have to clean the sides of the tunnel with acetone or thinners to ensure a clean surface for the glue to bond to. Any presence of silicone whatsoever will cause the glue to lose its adhesion. Cheers, Tony
| Re: Carpet on Centre Tunnel Use steam, it will make the carpet more pliable and take form easier, wall paper stripper will do the trick, I know it sounds daft but it works.
__________________ Gary Custom Exhausts & Headers Little boys wear Bowties, Flatheads are for nerds, Get real get Mopar ww.sidepipes.co.uk |
| Re: Carpet on Centre Tunnel Thanks all - will try some Evo Stick this weekend !!!!
__________________ Brian DB Replicas Dax-No 54 Engine back where it belongs - with upgrades New paint going on Dec 08 Looking forward to even more Smiles Per Mile in 2009 |
| Leather trimming the tunnel carpet ??? | kayjayd | AK Technical Questions | 6 | 05-10-07 10:02 PM |
| Tunnel run, | scubie | Events | 1 | 13-01-07 12:05 AM |
| Transmission tunnel | richc | DAX Technical Questions | 14 | 30-10-05 12:12 AM |
| Rotherhithe Tunnel | j9kks | Spotted, Was it you????? | 0 | 28-07-05 11:38 PM |
| AK transmision tunnel | tony | General Cobra Discussion | 1 | 03-10-02 03:01 AM |
