Old 19-07-04, 09:21 PM
Chevy Flywheels
Cool,
Smashed through the 14k barrier, with just the faintest whimper from my ailing bank account.
Still not got anything other than a chassis assembled, but things are moving, somewhat in the wrong direction at the moment.
Got the Tremec gearbox package for the SBC from Brian at repower about 5 weeks ago, and now my engines arrived i've found the flywheel doesn't fit.
Is this just a simple swap, ie are there two types and i've got the wrong one, or is the start of a whole series of nightmares?
Will the existing clutch plate & housing fit the new flywheel, or will i need the whole lot swapped?
Have to give him a call tomorrow and find out.
Old 19-07-04, 09:25 PM
kdavies3's Avatar
Re: Chevy Flywheels
what is it that doesn't fit ?
there are two ring gears available so you need the starter motor to suit which ever you have.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 19-07-04, 09:46 PM
rich's Avatar
Re: Chevy Flywheels
did you get your chevy from E. Factory?
If so did you change the spec as thay fit auto flywheels as standed?
Rich
You know it makes sense
rich.
All Things Cobra.Com
the cobra builders resource
Old 19-07-04, 09:48 PM
Re: Chevy Flywheels
I think things are somewhat more serious than that.
The bolts are set at a different diameter, and the hole in the centre is a different diameter, and the outer toothed ring is another diameter.#
In short it don't fit!
Engine came from EF, but they knew i was sourcing a manual flywheel & box from the UK, ie from Repower, so it came without one.
Old 19-07-04, 10:04 PM
kdavies3's Avatar
Re: Chevy Flywheels
I suspect you have a ford flywheel or something daft.
I think there's only one crank bolting pattern for SBC's.
Kev Davies
South Wales
Old 19-07-04, 10:38 PM
Miket's Avatar
Fully Paid Up Grandad
Re: Chevy Flywheels
Check the teeth on the flywheel
168 and 153 Chevy
130 and 143 Chrysler
184 and 157 Ford
166 Pontiac
In the summit catalogue they do Chevy 168 and a 153 tooth internally balanced and a 153 tooth externally balanced with small journal ring gear.
Don't know if this makes sense to anybody
AK 427 FOR SALE
PistonHeads AK for sale
Mike
AK Sportscars
355 Hauser Chevy
Old 19-07-04, 10:48 PM
Re: Chevy Flywheels
There are different bolt patterns for different chevy cranks (maybe 3) as well as the 2 different ring gear tooth patterns. I have a 153 tooth twin plate steel sfi clutch combo and I now it didn't fit one crank I tested it on.
Aka Boosted LS1, Boost it
Old 19-07-04, 10:59 PM
Re: Chevy Flywheels
OK, bit of measuring..
The flywheel i have from Repower is 153 teeth, 2.5 inch hole in the centre and 6 bolt holes 45mm centre to centre.
The crank has a 2" casting in the middle, with bolt holes 37mm centre to centre, and the starter is set for a 168 tooth flywheel.
Old 19-07-04, 11:11 PM
Miket's Avatar
Re: Chevy Flywheels
Flywheel 153 teeth up to 1985
Flywheel 168 teeth up to 1985
Flywheel 153 teeth 86 onwards
Flywheel 168 teeth 400 SBC
AK 427 FOR SALE
Mike
AK Sportscars
355 Hauser Chevy
Old 19-07-04, 11:15 PM
Re: Chevy Flywheels
Hey Mike,
You dont own a dark (brown/bronze) mondeo estate do you ?
Just that driving up from Plymouth a couple of weeks ago i passed a car of that description sporting a bumper sticker strangely simlar to your sig.
Billet Flywheels and Bullet Proof Bell... Warren General Tech Tips & Questions 7 22-06-06 09:31 AM
Flywheels chesterak Engine Tech Tips & Questions 2 29-11-03 12:15 AM
Chevy LS1/LS6 chesterak General Cobra Discussion 5 28-09-03 10:22 PM
chevy 302, or is a 327?? the4bidden General Tech Tips & Questions 6 15-12-02 07:48 PM
Flywheels steve_a_uk General Tech Tips & Questions 1 17-02-02 11:02 AM
