Another good day
Well, today was the time to get the engine (350 Chevy) onto the chassis. My first challenge was to get the engine out of my front garage through the single door at the back... Once engine was mounted onto the proper V8 lifting tool, all went relatively well... Found out after mounting that the 3/8" fuel pipe I put there is in fact not long enough, so now have a choice to extend it with a new piece of copper nickel by about 1 foot, or to use the flexible pipe under the edge of the bell housing to the fuel pump.... What do people think?...
Engine mounts supplied by AK were pretty exact in their mounting positions. Great job.. Anyway, now time to add all the anciliaries and get to a position where I can add the body....
-------------------------------------- AK427, -------------------------------------- |
Re: Another good day
Hi Dave,
my diff is a 3.31.... And you are not telling me something I already know.. How do yer know that stuff for my gearbox!!!... If I set my rev limiter to 6000 what is my top speed??? Cheers Carl..
Hi Goldie.
140 MPH:thumb: 4 speed boxes almost always have a ratio of 1:1 for top Do you know if your box is a close or wide ratio? I could give you the rpm/ mph for all gears if you know which box you have. Nothing clever on my part, I have a programme called Motormath that "Bowtie" wrote some time ago and made it downloadable from here but the link doesn't seem to work these days.
Pro Dax Builder Current builds:- Dax No.123---------Kirkham No. 1 |
ah,
I do not know if it is close or wide ratio...!!! I will see if I can try find out either way which it is, unless you know how to tell? cheers Carl..
Here are the two different ratio sets:-
(And the speed per 1000 rpm) Close:- 1.................220:1................11mph 2.................164:1................14mph 3.................147:1................16mph 4.....................1:1................23mph Wide:- 1................252:1...................9mph 2................188:1.................12mph 3................147:1.................16mph 4....................1:1.................23mph The beauty of a 5 speed box is that with a 5th gear ratio of 0.67:1 (Tremec and such like) you would have 35mph per 1000rpm in 5th. Not much good for thrashing about but great when you want to save some fuel and your ear drums on a long run........Like going to Stoneleigh or Elvington etc.:thumb:
Excellent,
thanks for that!! Maybe I can take the side panel off and count teeth??
Just put the box in first gear then turn the input shaft and count how many turns are needed to make the output shaft turn once. 2 1/4 means it is a close ratio and 2 1/2 turns means that it is a wide ratio..............Easy peasy:thumb:
Ahhhhhhh,
just got to figure out how to turn the input shaft now??
| Good Day Out........ | Colin GD427 | General Cobra Discussion | 33 | 12-07-04 07:55 PM |
| Had A Good Day | Rodders | General Cobra Discussion | 1 | 05-07-03 11:00 PM |
| This any good for anyone? | cgnw28517 | General Cobra Discussion | 2 | 18-06-03 10:58 PM |
| How good are you? | Dutch Paul | General Cobra Discussion | 2 | 26-01-03 08:58 PM |
| Any good? | whitty121 | General Cobra Discussion | 2 | 24-05-02 10:37 AM |
