Old 30-09-04, 07:02 PM
Engine start up
OK, the time has come to start up the beast.
The dials have arrived, i need a few hours to jury rig the power and sensors, and as long as the boys arrive to lift the body off out of the way, its a green light for saturday.
The engines been run in already in the US, so the cams are all sorted. Any last minute tips like, turn it over until the oil pressure comes up with the plugs out, then whack them in and see what happens.
fire extinguisher at the ready!! :thumb:
Old 30-09-04, 07:12 PM
Club Sec/Rep Liason
Re: Engine start up
Plenty of petrol in reserve, once its started you wont want to turn it off :thumb:
AK 427 351C T5wc
Old 30-09-04, 08:43 PM
Andy302's Avatar
Re: Engine start up
Bottle of grinaway? Bribe for the neighbours? - Sorry Im sure someone will have some useful advice soon!
Andy
www.andysgd427.blogspot.com
Old 30-09-04, 08:55 PM
Re: Engine start up
Packet of condoms..
Oops, did I say that?
Paul
Daytona 427..
Paul
Old 30-09-04, 09:04 PM
Re: Engine start up
Why? doing it single handed and don't wanna get your hand dirty?
Steve
Steve Richards
LS1..........so smooth.........so economical!
Growing old is inevitable - Growing up is an option
Old 30-09-04, 09:40 PM
gareth08's Avatar
Re: Engine start up
Yep
5 gallons fuel,24 Stellas,40 fags and lots of fun.
Gareth
Gareth
Old 01-10-04, 09:41 AM
kdavies3's Avatar
Re: Engine start up
Hopefully I'll be able to hear it 40 miles down the M4.
Good Luck. :thumb:
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 01-10-04, 03:19 PM
Re: Engine start up
I would still be inclined to prime the engine first by taking the dizzy off and driving the oil pump with an electric drill and extended shaft, until oil appears in the rocker cover area via tha push rods.
Make sure the oil pump is rotated anti clockwise if its a Ford (dizzy at the correct end!) :thumb:
and clockwise if its a Chevy (dizzy at the wrong end) :finger:
No need to take the plugs out if you prime her first. GOOD LUCK!!
Cheers !!
David
Old 01-10-04, 04:27 PM
Re: Engine start up
Hmm. I may well scibe a line down the dizzy and mounting, whip it off and see what is required.
A power drill i have, an assortment of metal bits i have, a chevy dizzy input shaft i'm kind of lacking.
Do i just need what looks like a bloody big flat blade screwdriver on a drill? (Perhaps a long flat wood drill bit, then the pointy bit will keep it central on the oil pump as it spins?)
Old 01-10-04, 05:59 PM
Dax SC's Avatar
Re: Engine start up
Grease,No need to prime, as the engine is not completly dry. Just fill up with oil (use a good quality non synthetic oil such as Vavoline or Castrol GTX), disconnect ignition (red lead to HEI coil) and turn over the engine until you get oil pressure. Reconnect ignition; check fuel, pump accelerator once to ensure auto choke flap is closed. Ensure leads are clear of exhaust ports if you are running without headers. Have you connected up coolent hoses? If not do not run engine for more than a few seconds as it could damage water pump. If you have connected water hoses, after running engine for a short period, drain coolent and refill (coolent may be rust coloured initially from surface rust inside the block coolent galleries). To protect engine, use a good 50/50 antifreeze mix to protect againt corrosion.
Have you fitted a throttle return spring?
You should now be good to go. WARNING - when that puppy fires up it will scare the **it out of you!
Mark Smith
Engine First Start mjculley General Tech Tips & Questions 6 16-09-04 08:52 PM
Engine Start Up midlifecrisis General Tech Tips & Questions 3 20-07-04 09:11 PM
engine start adyv8 Pilgrim Sumo Technical Questions 0 18-07-04 09:55 PM
Help!! Engine won't start roll control General Tech Tips & Questions 49 07-07-04 09:50 PM
Engine start. tony General Cobra Discussion 11 07-11-02 09:17 PM
