| Brake Problems Hello guy's I have filled brake resevior for the first time tonight...and bled each calliper in turn untill fluid comes out of bleed nipple.....No Problem!! Back brakes work (cant turn wheel round with brake on).....but fronts....not working at all. When i was bleeding the rears..i noticed that the pedal travelled 'further' than when doing the fronts!!!! Has anyone had similar problems?? Only thing i can think of is that front calliper pistons are seized!!.....any other ideas?? thanks guy's.........steve |
| Re: Brake Problems Your observation about pedal travel leads me to think that you still have air in the front system. If the calipers were seized and the system fully bled the pedal would be very solid and you would get less travel while bleeding the rears. Alternatively the master cylinder is assembled wrongly and is not pressurising the front circuit at all. I assume that it is dual circuit?
| Re: Brake Problems Have you got a pressure limiting valve in the circuit anywhere?
| Re: Brake Problems Hi Myles....thanks for quick reply...yes..it is dual circuit steve |
| Re: Brake Problems Of course it is, you have the same car!! If you bleed the fronts on there own (back circuit left open) the pedal should be quite firm, especially if the calipers are seized. If not, look for an air lock somewhere. I used one of those beeding devices that pressurises the system using a spare tyre and they are very good.
| Re: Brake Problems Myles....I have not fitted a pressure limiting valve in the circuit at all....and actually used the type of bleeding device u suggested cheers...steve |
| Re: Brake Problems Totally agree Chris...but after i used the 'easy'solution.....i did actuall re-bleed each corner by the 'old fashioned method'.......no air coming out.only fluid.....but still no brake!!! steve |
| Re: Brake Problems What is the state of the master cylinder then, is it new?
| Re: Brake Problems Sorry Steve we were obviously typing at the same time
| Brake Problems | robinj66 | General Tech Tips & Questions | 5 | 17-11-06 05:25 PM |
| More brake problems!!!! | 427sc | General Cobra Discussion | 17 | 27-10-04 10:29 PM |
| RV8 Problems | Phil McCann | Engine Tech Tips & Questions | 10 | 14-08-04 11:00 AM |
| Brake Problems | laner | General Tech Tips & Questions | 3 | 05-08-04 09:21 PM |
| 2nd attempt Brake at which brake discs!! | Andy302 | General Cobra Discussion | 1 | 08-05-04 07:31 PM |
