Old 13-10-04, 12:26 PM
Jag Speedo Sensor
Hello all you wonderful people,
I've done some digging and would quite like to use my jag speedo sensor, since theres a hole in the diff already just waiting for one.
The problem is mine is FUBAR as the greebo that removed it from the car did so with a lump hammer. Having spoken to Jaguar i would need to sell the GD to be able to afford a replacement one...
I heard stories a while back about some of you removing it, covering with a blanking plate and dropping the sensor on a shelf in a dark corner of the garage.
Will that man step forward and claim a negotiable prize in exchange for a second hand jag speedo widget?!
Old 13-10-04, 12:36 PM
kdavies3's Avatar
Re: Jag Speedo Sensor
I must admit that I'm not familiar with a speedo sensor going in the diff?
Does it monitor the crownwheel or pinion?
Most sensors pick up from the propshaft often from the prop bolt heads themselves.
The only holes I know of in the diff are the oil fill and oil drain, also the breather in the rear cover.
Kev Davies
South Wales
DAX, 383 Chevy Stroker,
Old 13-10-04, 02:07 PM
russell_ram's Avatar
Club Treasurer
'I must admit that I'm not familiar with a speedo sensor going in the diff'
FYI : XJS, cast Al cover, below the breather. 10 pulses per wheel rev, picked up from either a machined 'castlation' on the RH half of the PL unit or from the later, cost reduced, pressed on steel version of the same.
Pick-up is the same as the one used on XJ40 - but on XJ40 it mounts to a cast Al bracket which positions it to pick up off a pressed ring mounted on the (LH?) output shaft.
Russ
Old 13-10-04, 02:22 PM
I've now spoken to Ed at Wards and he's (hopefully) got one on a shelf somewhere at a fraction of a fraction of the price of a new jag one.
Now all i need to work out is what flavour it is. ( i suppose it can't be reed & magnet) Russ cheers for the mail, i'll have a play tonight and try and check my current / resistance if i can get to what wire i have left.
(Kev, they do exist, and i've got one. See thread Fuel pipe routing )
Old 13-10-04, 02:36 PM
kdavies3's Avatar
Well I never!
You learn something every day. :thumb:
Kev Davies
South Wales
Old 13-10-04, 03:00 PM
Club Treasurer
If it's any help (coz I was late this morning and forgot to pick one up on the way out the house) the Jag sensor has two/three wires. One red, one blue and a braided earth shield. I can do some multimeter continuity tests tonight, it's just easier to see small signals on an oscilloscope (and I've got variable power supplies at work).
Russ
Old 13-10-04, 05:15 PM
I have Got a sensor, bracket and cup that I have just stripped off my LSD. I know it is working because it came off the car I have been using for the last 2 years before it became an organ donor.
If you want I can bring them back to Bath with me at the weekend...............open to offers as I have new sender in my gearbox..
tel 07966180966 let me know
john
WAHOOOOOOOOO: ON THE ROAD AT LAST.:drive:
Got my MSA Licence hillclimbs here I come.......wheeeeeeeeeee!
JUST NEED A TYRE SPONSOR NOW>>>>
Exhausts & headers made by Mark (fat boy northern)
Old 13-10-04, 05:16 PM
Also have XJ40 manual for the connections
john
Old 14-10-04, 12:04 PM
John,
I will be in Bath on Friday for the beer festival. If you're around i'll give you a ring and we can negotiate a price. I dont suppose you have one of the brake line 't' pieces, as attached to the front and rear subframes, going spare as well do you?
Adrian
ETB Speedo Sensor Marc General Tech Tips & Questions 4 03-01-07 05:20 AM
GD Speedo sensor Glyn_Turner General Tech Tips & Questions 2 26-08-05 01:12 PM
ETB Speedo and SD1 sensor chesterak General Tech Tips & Questions 15 06-05-05 03:55 PM
Speedo Sensor greenster Pilgrim Sumo Technical Questions 7 06-07-04 12:10 AM
Speedo Sensor location. Dan General Tech Tips & Questions 16 05-08-02 08:45 PM
