| Re: Cobra running gear If the top of the suspension was just an A frame I would have no worries about the setup, but as the whole suspension force is going through that drag link coupling and the strangely fragile looking pivot I would have many worries. This is a dreadfully suspect design, the forces that this coupling was designed for are parallel to the centerline of the thread not at ninety degrees. The fact that the joint can also rotate in the A frame without positive keying is also a worry. But then, hey, I won't be driving in it. Time for a little thought I think. Paul.
__________________ All the best Paul. |
| Re: Cobra running gear Quote:
Andy doesn't muck about where mechanical design is concerned, that is the way to do it!
| Re: Cobra running gear Very true Purple, 52 must have been a good year. It worries me greatly that such a design should be sold, I'm assuming that this is an available kit. Whats the deal with inboard shocks anyway, they will be directly in the radiator outflow and very hot, I prefer my shocks to keep cool, OK unsprung weight is a design consideration but less so on a car with a lump checking in at 350Kg ++ Maybe I'm getting a little old. Regards Paul.
| Re: Cobra running gear Here in NZ the certification process is administered through independant engineers and the New Zealand Hot Rod Association. They have a build manual 'bible' type technical book that lists many do's and don'ts for one-off and modified chassis. It specifically mentions that you must not use track rod ends as ball joints. As to Paul Gayter's comment: I agree, I was always led to believe that inboard shocks where mainly for aerodynamic benefit. On a single seater, removing the shocks from the frontal area of the car reduces drag. On a bodied car it makes little difference.
Which normally results in a locked thread! It is as yet, a proven product. I saw the prototype chassis a couple of years ago at one of the shows, and thought that dosn't look right. Because it was the first chassis, I didn't really take it on board. The pervayor of the kit is adament that it is the best Cobra kit to hit the market in recent years. He appears to have the backing of two of the three Kit Car mags!! I have said too much already ![]()
It's comforting to see that other people are "Spooked" by that front suspension....I was begining to think I was going mad when I first saw it. ![]()
| Re: Cobra running gear Looks to me like the reason the coil overs are inboard is because there wasn't room anywhere else. Anyway, where are all the suggestions for alternative running gear? Thanks Myles. Had thought about toyota supra stuff. There were suggestions of using a dead triumph stag at the pub last night but this is probably because there is a guy there with one spare. More thought needed.
__________________ A S motorsport Ltd. 01379 688356 mob; 07909531816 web; asmotorsport.co.uk email \"andrewsoar@yahoo.com\" |
| XJ6 running gear | martin_t | General Tech Tips & Questions | 10 | 26-12-06 11:09 PM |
| Jag Running gear | rlagden | Newbies | 12 | 02-11-05 12:16 PM |
| Euro 427 (fiero) cobra Running Gear | mouldb | General Cobra Discussion | 5 | 23-02-05 11:01 PM |
| Running Gear | Andy302 | General Cobra Discussion | 7 | 27-08-03 12:46 AM |
| Running Gear | Andy302 | General Cobra Discussion | 4 | 17-04-03 10:27 PM |
