| Re: brake light failure Strangely at the Le Mans classic this year we had two of them fail on two different Cobras, although Plods turned out to be a wiring problem. :thumb:
| Re: brake light failure Dave, I had a similar problem with mine a few months ago.. would only work when you stamped on the pedal. It seems like the switches need a fair amount of pressure to "switch on" the circuit. Thanks to some advice from WIRES on the forum I fitted a relay into the circuit which switches much faster and it works a treat now and the lights come on much quicker. It saved me having to buy a new brake switch. I think I might have the wiring diags still if you want them. Cheers, Kevin..... |
| Re: brake light failure Oh I do hope someone comes up with the solution soon as I was the silly b*gg*r behind him yesterday ! |
| Re: brake light failure Kevin T If you can find the diagrams or simply (and I mean simply) explain a solution I would be grateful. Andy s Next time I'll throw some new light bulbs over my shoulder and if you would be so kind to change them being as you were so close. Ps I think Roger should have done the Porshe it was a shame the lanes were so narrow. I think the 911 was pushing his luck. Bit of a Chav. Regards dave.n
__________________ billy no mates . South East Regional Rep SRV8 |
| Re: brake light failure Had the same problem on another car a couple of years ago. The pressure switch was old & sticking. It would only operate when the brakes were applied really hard. Changed the switch for a new one & problem solved. The brake lights then came on with only slight pedal pressure.
__________________ Roger Magnum MkI Still looking for the Last Open Road ! ! ! |
| Re: brake light failure The same happened to me on Sunday. But no matter how hard I pressed on the brake peddle they would not light. So will have to investigate further. Loose wire, faulty switch, or maybe a relay. Thanks for the info.
__________________ CHRIS Gardner Douglas Mk3, Chevy 350, 420bhp. Black and looks the business |
| Re: brake light failure Simple test, get a continuity tester on the switch and put light pressure on the brake. If it doesn't show a connection, the switch is buggered. Happened to me ages ago, on my Mini (i think?!) the switch being hydraulic fails easier than a simple reed / microswitch on the pedal itself. If it were me i'd just add a mechanical one and run the wires to it instead.
| Re: brake light failure My switch failed on the way over to Le Mans this year. This was a real pain, keeping reminding the guys behind me got irritating for all of us. I bought a new switch, I think it is a VW Golf 1980's one, swapped it, no need to bleed brakes if you're real quick. No problem now. Cheers, Neil.
__________________ Crendon, Ford Sideoiler 427 |
| Re: brake light failure Quote:
__________________ Rodders has a Raspberry Red one with Stripes ( No 57 ) Dax Chevy 5.7 V8 Built by D B Replicas 2003 |
| Brake light switch Pt No. | futureproof | DAX Technical Questions | 0 | 14-01-07 11:48 AM |
| Brake warning light came on | Robin427 | General Tech Tips & Questions | 12 | 28-06-06 11:21 AM |
| Brake warning light | Mat | Pilgrim Sumo Technical Questions | 4 | 18-07-05 03:41 PM |
| Brake Light Switch | V8 BJC | General Cobra Discussion | 4 | 12-06-04 10:13 AM |
| tojero brake failure | Paule | DAX Technical Questions | 4 | 12-03-04 04:51 PM |
