Old 06-12-04, 08:43 AM
pat b's Avatar
Club Nuisance
Oil pressure to high ??????????????
Smiths gauge and S/B Chevy. Oil pressure stays at 40 p.s.i. all the time even at tick over or high revs Dont think its gauge as goes back to 0 when engine stops. Any help pls.......... PAT.........
PHON NUMBER 07811367233 Its good to talk cos i ca nt typp very weii......................:-}DONT BE SPINELESS OWN A GARDNER DOUGLAS THE ONLY SNAKE WITH A BACKBONE
Old 06-12-04, 09:37 AM
Re: Oil pressure to high ??????????????
First off, is it an electrical or mechanical sender?
If its electrical:
Check the gauge says zero with the power to the gauges on but the engine off.
Short the sender wire to ground (anywhere on the engine should do) It'll take a few seconds but should move up to read maximum.
If this works, you must have a dodgy sender unit, if not you have a dodgy gauge.
If its mechanical:
Get an electronic one like me and repeat step 1..
Old 06-12-04, 04:42 PM
pat b's Avatar
Club Nuisance
The switch is mechanical, pipe from block to gauge. Any body help pls... PAT....
Old 06-12-04, 06:33 PM
Is it a hi volume (bbc) pump? What speed is tickover? Solid lifters? It could be that there is nothing wrong with either the gauge or the engine. Perhaps the gauge is just a bit sticky such that you don't see the drop at tickover. I agree that 40psi at tickover is unusual for a Chevy, 25psi is more typical.
Myles D-W
Old 06-12-04, 07:16 PM
Mine shows 75 psi at tickover when the engine/oil is cold. This drops to 35 or so when hot. (Tickover hot that is. I've yet to rant it so have no idea what it will read when the oil is properly hot)
Perhaps you could attach a bicycle pump or something to the gauge and just try pumping different amounts and see that the gauge moves up and down without sticking.
Not much else i can think of other than trying a different gauge on the engine.
Old 06-12-04, 07:21 PM
Club Sec/Rep Liason
Pat.
I got an old gauge your welcome to borrow. Pm your address and i'll put it in the post :thumb:
Also what oil are you using and when was it last changed? I had a less than happy oil pressure until I changed to Valvoline 20/50. Stays at 75psi hot or cold now
AK 427 351C T5wc
Old 07-12-04, 06:02 PM
Neil O's Avatar
Pat, my Chevy runs at about 40-50psi (mechanical guage) and drops a bit on tickover but not much at all.
I've just changed to Valvoline Racing Oil and this has pushed the oil pressure up slightly. It now seems to get up to the 50 mark at anything over 1000rpm and doesn't drop back as much on tickover now.
My guage is sticky when starting now but wasn't when I first had it (approx 2 years ago). This can be a problem if you have an oil pressure safety relay working with your electric fuel pump (if your fuel drains back to the tank when engine is not running).
Try Purple's offer of his spare pump for peace of mind.
Neil.
Crendon, Ford Sideoiler 427
Old 08-12-04, 06:19 PM
Andy S's Avatar
Pat I would concur the figures above, my SB Chevy sits all day at 50psi when under load etc and drops back slightly (to about 35) on tickover.
Andy S (Maggot)
SRV8 + CHEVY
Isnt it a beautiful day - now watch some bastard louse it up !
Old 08-12-04, 06:52 PM
Mine too is 35-50 from idle to 2000rpm+. It is a high volume pump with a de-rated spring.
Old 09-12-04, 02:10 PM
pat b's Avatar
Club Nuisance
Thanks for all your answers and Chris i will P M you later thanks for offer.Have not been ignoring this link just cant get my comp to log on to this site and when I do cant see new posts.......SH** my logs a pain in the A**....... PAT......
High price? Stu J General Cobra Discussion 9 18-12-07 11:16 AM
Oil Pressure Too High?? Dutch Paul Engine Tech Tips & Questions 41 12-08-06 12:45 AM
High Wycombe stevee8 Spotted, Was it you????? 7 10-07-05 06:27 PM
Oil pressure too high when cold ? David Horsnell Engine Tech Tips & Questions 12 08-04-05 06:30 PM
High mileage LS1 Robin427 General Tech Tips & Questions 3 28-12-03 10:44 PM
