Old 09-01-05, 05:58 PM
LS1 Starter
At the wiring stage and thought I would try a test fire to give me the confidence that all was well.
Well it wasn`t !!! Just a clunk and nothing else.
The engine can be rotated via crank pulley so that should not be an issue.
Confirmed wiring size and connections must be OK and battery was recharged overnight just to make sure.
So decided to strip it out after long deliberation as it must be the worst possible thing to remove with the body on and exhaust in place.
A standard oil pan would have made life easier but the corvette winged version hides everything.
So to a bench test .................
The throw out pinion certainly throws out but stays there.
Should it continue to rotate ????? Any thoughts please.
Trevor
GDO5COB
LS1 / T56
Old 10-01-05, 12:40 AM
Re: LS1 Starter
Sorry to hear that, Trevor. I had a problem with mine that turned out to be a loose connection onto the starter relay. Your problem sounds a bit different and I imagine you checked for that...
... if you want to swap for a standard oil pan, then let me know!!
Reverend Robin
GD427 Euro
World Rivnut Champion 2007
Old 10-01-05, 12:24 PM
davidcot's Avatar
Re: LS1 Starter
Just a thought. Have you connected the earth strap from chassis to engin?
As I had the same issue.
David
GD427Mk3 Chevy 350CI On the road May 2008
Old 10-01-05, 01:10 PM
Re: LS1 Starter
I have so many earth straps you would not believe !
The final test was done on bench with pos & neg of battery direct to main posts and a pos for solenoid signal.
Just no rotation once the pinion had fired out with a hefty clunk.
Trevor
GDO5COB
LS1 / T56
Old 11-01-05, 04:35 AM
Re: LS1 Starter
Sounds knackered - I'll sell you my engine for £7000...
Reverend Robin
GD427 Euro
Old 11-01-05, 12:44 PM
Re: LS1 Starter
Robin
Thanks for that kind offer but in this instance I think I will decline.
Just bought a `new` one off e bay for £ 88 . (without a core charge which seems common as only re engineered units seem to be available )
Might have to get the wiring in place whilst waiting.
Trevor
GDO5COB
LS1 / T56
Old 11-01-05, 07:29 PM
Re: LS1 Starter
Seems like a bargain - good luck! Let me know if you have any problems with the wiring...
Reverend Robin
GD427 Euro
Old 22-01-05, 06:00 PM
Re: LS1 Starter
Starter issue resolved thanks to PaulF who has concluded that there is NO need for the earth connection.
Therefore for anyone at a similar stage :-
Battery positive to terminal post at 7-o-clock
and Starter positive signal to small post at 11-o-clock
Earth is taken through case.
Nett result ....... fired and ran first turn and sounds great.
Only a couple of starts at tickover produced 40 psi oil pressure within a few seconds , so pretty chuffed.
Trevor
GDO5COB
LS1 / T56
Old 22-01-05, 07:05 PM
Re: LS1 Starter
Congratulations! Was this with the new starter motor or the old one? How did you set up your fuel pressure?
Reverend Robin
GD427 Euro
Old 23-01-05, 12:28 PM
Re: LS1 Starter
Robin
I used the original starter motor - so my efforts didn`t b***er it up.
Fuel pressure set with 60mm gauge plus adaptor and fitted to one of the spare ports on the pressure regulator.
Just a small oil leak to cure from the oil press. & temp manifold block to side of oil pan.
Trevor
GDO5COB
LS1 / T56
Starter Circuit Martyn-ak427 General Tech Tips & Questions 9 28-08-07 05:10 PM
Starter her for the first time bc_suv General Tech Tips & Questions 8 26-03-06 08:01 AM
Hello to all and a starter for 10 nobbystiles Newbies 6 24-02-06 11:40 AM
Starter-less LS1 Robin427 General Cobra Discussion 2 25-03-05 12:27 AM
Starter Migge General Cobra Discussion 4 23-07-04 12:19 PM
