| Sierra column I was thinking of changing my column stalks for the shinybitz stainless ones. My problem is I have the square hazard light column which has the horn on the stalk. This leads me to the following questions.... 1.Is it okay to have a horn button on the dash? 2.can the column be modified so that a centre horn can be fitted? 3.Is it easier to change the column altogether and get a round hazard light with centre horn fittings? 4. forget it altogether cheers Mike |
| Re: Sierra column you can put a horn on the dash you can put a horn on the steering wheel easy enough, you just need the horn connector from the back of a sierra steering wheel. I am sure I just got the wiring bits from a scrappie, and used them on my column, I am pretty sure all the castings are identical
| Re: Sierra column Hi there I did mine some time back and put the horn button on the dash also had to put the washer button there (see article in the mag approx 3yr's ago cheers Paul |
| sierra steering column | vinster | Wanted Adverts | 3 | 18-12-07 06:13 PM |
| Sierra column switches | Daxman | DAX Technical Questions | 4 | 28-03-07 09:40 PM |
| Sierra Steering Column | wsnaith | DAX Technical Questions | 4 | 11-03-07 03:51 PM |
| Sierra column stalks - Again ! | Jake | General Cobra Discussion | 7 | 04-10-04 08:41 PM |
| Steering column, SD1 or Sierra | DrFelch | General Tech Tips & Questions | 5 | 06-02-03 06:54 PM |
