| Re: Red Hot Exhaust Can only be to do with sparks or mixture. Easy to check timing and advance with a strobe but you really need a gas analyser to do an accurate mixture. excess heat usually point to a lean mixture, are your secondaries working? Andy S
__________________ A S motorsport Ltd. 01379 688356 mob; 07909531816 web; asmotorsport.co.uk email \"andrewsoar@yahoo.com\" |
| Re: Red Hot Exhaust Andy, For what its worth I had this on a Jensen Interceptor that I brought back to life and it was the ignition timing, literally moved the dizzy a bit and the manifolds went back to normal almost straight away. Can't remember if I had to advance or retard but it worked straight away. Cheers Alastair |
| Re: Red Hot Exhaust Retarded ignition will certainly make your headers glow. Unless your Dizzy has moved on that journey, I would have thought it would have come to notice before. Nick |
| Re: Red Hot Exhaust Well BOLL*CKS I still dont know whats wrong, had the man out this morning, he checked all the timing, mixture etc and all seemed ok, thought it might have been fuel as I did put a couple of gallons of Esso unleaded in her albeit on top of 6 gals of BP Ultimate, never been a problem before but you never know,so I put 1/2 bottle of octane booster in the tank and took her for a short spin, litterally 4-5 miles, and guess what, bl88dy things were glowing again when I got back. So now I havnt got a clue, HAS ANYONE ELSE ???????
__________________ Andy S (Maggot) SRV8 + CHEVY Isnt it a beautiful day - now watch some bastard louse it up ! |
| Re: Red Hot Exhaust Andy, Has this only just started to happen? Or has it been like it since you've had the car??
__________________ Cheers !! David |
| Re: Red Hot Exhaust Check timing all of you and fuel pump. Also check components by which the timing is set...damper I think its called. If thats moved, then you'll alwys be setting it up wrong Paul
__________________ Daytona 427.. Paul |
| Re: Red Hot Exhaust Dave I had the guy over from Bodium this afternoon who did your engine (Tony?)_ and he checked all the timing mixture etc and we couldnt really find an explanation. Since then have spoken to Dave Brookes,cheers mate, Real Steel who build the engine, and Thunder Road Cars,very very helpful. Think I may have found the problem, its possibly the vacuum advance not working. Checked it by taking the pipe off the carb and sucking on it and the end in the dizzy didnt move, mech advance is fine rotor arm moves ok. So I.m now suspecting this is the problem, just dont know yet whether its corroded in the dizzy and seized or its the diaphram in the vacuum unit. Hope to be able to check tomorrow.
| AK exhaust on a Dax? | Wilburn | General Cobra Discussion | 10 | 08-11-07 10:18 PM |
| exhaust! | shiney | DAX Technical Questions | 7 | 30-09-05 05:37 PM |
| exhaust diy | neil still building it | General Tech Tips & Questions | 16 | 29-09-05 06:14 PM |
| New Exhaust | marc davis | Newbies | 6 | 12-02-05 12:56 PM |
| red exhaust | mikeb | General Tech Tips & Questions | 7 | 02-07-04 11:16 AM |
