| Stuck Clutch Help me please! I tried to go for a mid-winter drive today, but came up with a bit of a problem and I'm hoping someone on here knows the answer... The clutch has stuck, and doesn't disengage when I press down the pedal. I've tried putting it in gear and starting it, with no success. Then tried hand-braking while the clutch is down, with similar success. I've done both of these in 1st and reverse. Then I tried handbrake and braking hard, dragging the front wheels backwards. To no avail. Is there an easy way out of this (please say yes!) or is it gearbox & clutch out? If so I'm screwed as where it's being kept there's no power or light, and no tow point on the car to move it... The car is a RAM, 350ci Chevy, with a Toyota Supra gearbox. It hasn't been driven since about August (remiss of me I know, but work has been hell...) |
| Re: Stuck Clutch Try this, somehow wedge a bit of wood to hold the clutch pedal down and leave it overnight. This has been known to work before although I've never had to do it myself.
__________________ Keith S Built a Sumo 3 RV8 Sold it to buy a 2000 Chimaera 4.5 |
| Re: Stuck Clutch Put the rear securely on axle stands. Start in 3rd or 4th gear. Press hard on all three pedals simultaneously.
| Re: Stuck Clutch Perhaps you can open the bottom part of the bell house and try to use and screw driver at the same time some one push the pedal. It will be better is you run the car for a while till it get hot that will help. Humidity at the garage (in not frequent drive cars) is one of the most problem makers of our hobby. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Re: Stuck Clutch Andrew, That's a neat trick matching the Toyota gearbox to the SBC! It sounds like the engineering is not quite complete, however. Are you using a cable to activate the clutch or a hydraulic system? If it's a cable, it could have become frayed and may be stuck in the cable sleeve. If it's hydraulic, did you use an external slave cylinder or one of the units that mounts internally? If you have an external slave cylinder, does it move back and forth with the pedal operation? If it doesn't, then the lever may be stuck on something. If it does and the lever sticking out of the bellhousing is moving too, then you have to check the throwout bearing. Can you see into the bellhousing with a flashlight? It sounds like the throwout bearing may have come off the end of the transmission input tube. If there is a large enough hole, you may be able to re-align it with a long screwdriver. Make sure someone's holding the clutch down though. If that thing pops loose while you have a screwdriver inside, it could ruin your whole day! You're dealing with serious pressure, here. If you have the type of hydraulic throwout bearing that mounts inside the bellhousing. Look for leaks of brake fluid. Regardless, the transmission will have to be pulled. This is a problem with the internal units. They over-extend as the clutch wears until the seals come off their mating surface. You may have to make a spacer to fit behind it so it stays within it's recommended travel specifications. You might think about converting to an external slave cylinder setup. These are so much easier to service. I hope this helps, Paul
__________________ It doesn\'t have anything on it that doesn\'t make it go faster! |
| Re: Stuck Clutch Andrew, I reread your post and rethought the problem. It sounds simpler. If you have a cable actuated system, probably the cable broke. Easy and cheap to fix. If you have a hydraulic system, you probably have a leak. Find it and tighten the joint or replace the bad cylinder. Paul
| Re: Stuck Clutch The old school way of dealing with this is to start the engine in neutral until it is warm. Then roll the car onto the flat (or slight downward incline if possible) and then start in 1st gear. Drive the car pressing on the brake while the clutch is depressed. It soon frees it fairly easily and it avoids straining the starter motor too much which can suffer long term damage. (Subject of course to checking the cable / fluid levels of course!
| Re: Stuck Clutch Forgot to say that the normal cause is just a dampish garage. Since I got my new garage that is attached to the house and just slightly warmer I have never had the problem. A little heater just to keep the damp out would solve the problem, and of course you can depress the clutch with a piece of wood when not in use (although that can stretch the cable)
| Re: Stuck Clutch As to causes, mine used to stick if only left for month or so. The clutch had been relined with a 'competition' material which I believe has more iron in in and so tends to rust onto the flywheel/pressure plate. I changed for a standard friction plate and the problem has never re-occurred no matter how long I leave the car.
| Stuck | AGroomster | General Cobra Discussion | 45 | 15-06-06 11:46 AM |
| Free My Stuck Clutch | Speedy Gonzales | General Cobra Discussion | 7 | 08-07-05 08:33 AM |
| Stuck clutch is driving me mad | Speedy Gonzales | Newbies | 5 | 02-05-05 10:41 PM |
| Focibly disengaging stuck clutch | mikey | General Tech Tips & Questions | 9 | 15-03-05 04:00 PM |
| Stuck Clutch | Grease Monkey | General Tech Tips & Questions | 7 | 12-02-05 06:55 PM |
