| GDJAG Brake Fluid Hi Guys, having trouble finding out which brake fluid to use. No reply from Wards who reconditioned the axles for me. Seems like Jaguars need a mineral based fluid. Nearest thing I've found so far is LHM+. Anybody gotta clue? Thanks and regards, Trigger. |
| Re: GDJAG Brake Fluid Whilst on the subject, is there a correct order to bleeding Jaguar brakes. :thumb: :thumb:
| Re: GDJAG Brake Fluid Quote:
Cheers Tony
__________________ Old enough to have known better! |
| Re: GDJAG Brake Fluid Thanks for the answer Russ! I read it on a couple of containers of brake fluid in a motoring shop. Two different makes both saying not suitable for Rolls, Citroen and Jaguar which need a mineral based fluid. So it's any DOT fluid, 3, 4 or 5.1, synthetic or not but not silicone? Regards Trigger. |
| Re: GDJAG Brake Fluid Cheers Russ New pads a lot better, but still suffering from long pedal travel before they bite, can't figure it as I have bled them as you suggest, they are solid till I start the engine and the servo kicks in, the they go virtually to the floor. ![]()
| Re: GDJAG Brake Fluid Mike. Did pads, shoes and wheel cylinders on the van a couple of weeks ago, Pressure bled them three times but still had a very poor pedal. It took a couple of hundred miles till they bedded in and the pedal came back up
| Re: GDJAG Brake Fluid I have had silicone fluid in since I built the car (all Jag brakes) and have had no problems with that. As for the order of bleeding the brakes: it can be done any time after completing the plumbing and before driving the car!
| Re: GDJAG Brake Fluid I also used silicone from the beginning (new system) ten years ago. System has been flushed since on two occassions. No problems. Re leeidng, I agree Russ's advice. I always follow this route on my car with no probs whatsoever.
| Brake fluid | Dek | General Tech Tips & Questions | 12 | 10-08-07 12:57 PM |
| Brake fluid | cliffords | General Tech Tips & Questions | 11 | 06-11-06 12:15 AM |
| Brake fluid | Pat | General Tech Tips & Questions | 1 | 15-07-04 10:06 AM |
| Brake fluid | chesterak | General Tech Tips & Questions | 5 | 09-11-02 07:52 PM |
| Brake Fluid leak | dave ridgway | General Tech Tips & Questions | 4 | 18-06-02 10:44 AM |
