| Stuck Clutch OK, i've now got the brakes fixed but the clutch is either: A) stuck, or B) not disengaging :angry: :angry: Having never had it actually working i dont know if the whole setup pushes the arm far enough to disengage the clutch but the plate is stuck after 6 months of being clamped together OR the arm doesn't fully disengage the plate. The pedal has lots of pressure from the top right down to the bottom of the throw so something must be moving, but it aint going to disengage. Before i try the old 'start the engine with it in gear and on stands, then with the clutch down, rev it, stamp on the brakes' approach, anyone got any ideas? (Its the Repower Tremec 3550 TKO package with hi-performance clutch plate, slave cylinder etc.)
| Re: Stuck Clutch Wilf, I'll have a rummage around under the car with SWMBO pressing the clutch tomorrow to see how far the arm moves. (it's adjusted so the first few mm of movement contact the release bearing, so any further movement will be compressing the release plate*) (* Assuming i've put it togther correctly
| Re: Stuck Clutch adrian just a thought......I have encountered similar results if the clutch plate is fitted the wrong way round apologies if this is a suck eggs thing just trying to help. good luck ..and well done to get this far, hope the speedo works ok
__________________ john WAHOOOOOOOOO: Got my MSA Licence hillclimbs here I come.......wheeeeeeeeeee! JUST NEED A TYRE SPONSOR NOW>>>> Exhausts & headers made by Mark (fat boy northern) |
| Re: Stuck Clutch John, Distinctly remember the plate saying 'engine side' or words to that effect and was fitted accordingly, so unless i had some kind of mental episode, its not that. :thumb:
| Re: Stuck Clutch If you happen across Bristol and see a bloke walking around with a face like a child in a sweet shop with his dad's credit card, that'll be me. Having checked the throw on the release arm (4-5cm) i implemented Plan A. Started in 4th Gear (on stands), hard on the clutch, revved the bugger and yanked the hand brake on. Sorted. (I had horrible visions of body off / engine out scenarios for a few days)
| Stuck | AGroomster | General Cobra Discussion | 45 | 15-06-06 11:46 AM |
| Free My Stuck Clutch | Speedy Gonzales | General Cobra Discussion | 7 | 08-07-05 08:33 AM |
| Stuck clutch is driving me mad | Speedy Gonzales | Newbies | 5 | 02-05-05 10:41 PM |
| Focibly disengaging stuck clutch | mikey | General Tech Tips & Questions | 9 | 15-03-05 04:00 PM |
| Stuck Clutch | Andrew Wilde | General Tech Tips & Questions | 18 | 01-02-05 10:47 PM |
